Author Topic: Newbie GroovyArcade Questions - How do I run FBA games?  (Read 2609 times)
jimmyj1979
  • Last login:May 02, 2022, 07:26:01 am
« on: December 21, 2018, 07:52:28 pm »
Hi Guys
Kinda newbie here...
I currently have a working Jamma 15khz Cab, as well as a working Rpi2Jamma system and everything is great apart from the Pi being a little underpowered.
I built a groovyarcade box based on all the online specs and have a Jpac. Everything works, installed groovyarcade with AttractMode front end, all ok. I can play Mortal Kombat 1, 2 and 3 flawlessly (flawless victory? :P)
The question now is how do i run my favourite 2d fighters like MvC SFIII:3rd Strike and SFZ3? I have previously run them using FBA under the Pi and they work well.
Can attract mode run FBA as well? How does this all fit into the GroovyArcade landscape? Is GroovyArcade just a shell for other Emus? or am I locked into the Mame landscape?
PS I am keen to stay within Linux unless there is compelling reasons to switch to XP or Win7, i have a Win7 install already for GroovyMame but havent done much with it yet.
Cheers :) Jim
PS here are some pics of my installs to date
https://imgur.com/a/rYUpJ0S
https://imgur.com/a/epgrBEt
SteelRush
  • Last login:July 13, 2025, 03:58:26 pm
Re: Newbie GroovyArcade Questions - How do I run FBA games?
« Reply #1 on: December 21, 2018, 08:36:35 pm »
If your PC is sufficient, just run SFIII and SFZ in MAME.  No need for a separate emulator.
Attract Mode can run any emulator or program, so you are not locked in by using it.
GroovyArcade is just a Linux distro that runs whatever frontend you configure.  As any Linux, there are multiple arcade emulator options.  The Raspberry Pi on RetroPie is running Linux as well for comparison.  The Pi tends to run older versions of MAME because the emulation was not as accurate, thus did not require nearly as much power.
« Last Edit: December 21, 2018, 08:41:26 pm by SteelRush »
jimmyj1979
« Reply #2 on: December 21, 2018, 10:49:48 pm »
Thanks mate, Im running the groovyarcade 2017 release, how would i know what version mame romset i need for the SF games?
My PC is an i5 Quad 4670 with 8gb ram and 2x120gb SSD's and an ATI 4550
SteelRush
« Reply #3 on: December 22, 2018, 06:57:13 am »
That PC should be plenty powerful to run even fairly demanding games like Blitz.  So SF III should be cake for it.
I personally use Windows simply because there are more emulators and games available for that platform.  You could just update GroovyArcade to the latest release so you are certain of which version you are running.
