Author Topic: Ultimarc U-HID NANO compatible with Happ Duel Pedals?????  (Read 1903 times)
pipesfranco
  • Last login:December 21, 2018, 08:08:07 pm
« on: December 21, 2018, 02:21:29 pm »
Hi all,
I want to know before purchasing if the U-HID Nano board from Ultimarc will work with Happ's Duel Pedals like these on EBay:
https://www.ebay.com/itm/Dual-Pedal-made-by-HAPP-mame-very-nice-item/320457635594?hash=item4a9cc3770a:g:gfMAAOxyuPtQ~ySW:rk:1:pf:0
also on their site https://na.suzohapp.com/products/driving_controls/50-2978-00
I have a PC in my cab and I wondered if the analogue input will work with these pedals?
Thank you in advance
  • Last login:Today at 05:25:15 am
Re: Ultimarc U-HID NANO compatible with Happ Duel Pedals?????
« Reply #1 on: December 21, 2018, 07:09:26 pm »
Yes, the U-HID can be configured to accept a variety of digital (microswitch), optical (spinner/trackball), and analog (potentiometer) inputs.
Before you purchase the U-HID Nano, add up the number of inputs/pins you need -- there's a good chance you'll need a second encoder.
For example, the dual-pedal set you linked to would need four pins . . .
- 5v
- Ground
- Gas pot wiper
- Brake pot wiper
. . . and adding a 360 degree steering wheel requires two more pins. . .
- Data line A
- Data line B
(Use the same pins for 5v and Ground that you used for the pots)
. . . plus a Coin button, a Start button, Exit button, and a sequential up/down shifter needs five more pins.
- Coin
- Start
- Exit
- Up shift
- Down shift
(Use the same pin for Ground that you used for the pots)
For that setup you need 11 pins, but the U-HID Nano only has 9.
pipesfranco
« Reply #2 on: December 21, 2018, 07:11:29 pm »
Thank you so much for your reply.
I am using the spinner and ultimarc steering wheel for the wheel so i just need the pedals to go to the nano.
So i guess it would work?
« Reply #3 on: December 21, 2018, 07:40:54 pm »
Yes.  Four pins for the pedals and five pins to spare if wired for dual-axis or three pins for the pedals and six pins to spare if wired for single-axis.    :cheers:
Single axis wiring:
- Pink = Vcc (5v)
- Blue-yellow = Wiper
- Blue-red = Ground
