Author Topic: AdvanceMAME on Vertical Monitor  (Read 2380 times)
daeven
  • Last login:July 15, 2022, 12:17:33 pm
  • Llama this!
« on: February 09, 2004, 11:38:16 am »
Chalk this up as a stupid question, but I can't figure out what changed.  I had an older version of AdvanceMAME runnung via AdvanceMenu on a vertical arcade monitor.  I just did the upgrade to AdvanceMAME 0.79.  Whether I use new .rc files or my old .rc files, AdvMAME is rotating my vertical games horizontal!  I'm familiar with the -norotate option on regular MAME, but I cannot find any similar option in AdvMAME.  What is the command and how do I get AdvMENU to send it to ADVMAME?  I did correct this with my installation of the older versions, but I can't figure out what I did.
General Zod
  • Last login:June 23, 2005, 03:58:28 pm
  • Banned
Re:AdvanceMAME on Vertical Monitor
« Reply #1 on: February 09, 2004, 11:44:12 am »
I've been really trying to learn AdvMAME, so this is something I've just encountered also.
Scroll down your advmame.rc file until you see the line
Display_rol
 or
Display_ror
Either one depending on how your monitor is rotated.
Your's will probably say "no" , just change it to "yes" and you should be all set to go.
Mike
daeven
  • Llama this!
« Reply #2 on: February 09, 2004, 11:52:02 pm »
Thanks - that fixed it!  I had to change the display_rol to yes to get my Midway games to display correctly.  Now if I could figure out how to change the settings for specific games that come in upside-down, I'd be all set.  Since I've got the latest version of AdvMAME, the number pad / key does it, but the settings aren't saved.
