Author Topic: Pacman Museum and Sanwa Joysticks  (Read 4175 times)
arquillos
  • Last login:March 02, 2026, 07:31:26 am
« on: December 18, 2018, 03:16:50 pm »
Hi!
   Iīve got a arcade with two Sanwa Joysticks (JLF-TP-8YT) connected with a PC motherboard using an USB interface (https://www.arcadeoutlet.es/en/usb-jamma-interfaces/27-jamma-to-usb-2p-2050000005008.html).
   Iīm trying tu run the "Pacman Museum" game with this controllers but the game doesnīt recognize them.
   With Xpadder I can use one joystick using the arrow keys...but I donīt know what keys are used for the second player! Iīm not able to find them :( :(
   Using the patch "PACBRCADE" (https://github.com/vikbez/pacbrcade) I program the x360ce with this controllers but none of them works with the game :( :(
   Anyone has had any luck using arcade controls and this game?
Thank you in advance!!!!
JDFan
Re: Pacman Museum and Sanwa Joysticks
« Reply #1 on: December 18, 2018, 03:27:11 pm »
Do you have it set to use keyboard or controller ?  :dunno
Press D to go to How to PLay and then select device to change to keyboard or controller - and it also shows the list of keys/buttons used for that game.
arquillos
« Reply #2 on: December 18, 2018, 03:32:31 pm »
Thankx JDFan!
Yes I did it :)
The game shows the controls for only one player! So I can use Xpadder to play the game with the Sanwa stick! But only for one player.
I donīt know why it doesnīt show the controls for the second player :(
JDFan
« Reply #3 on: December 18, 2018, 04:17:19 pm »
Thankx JDFan!
Yes I did it :)
IIRC in order to play 2 or more players you need to use xbox controllers - the keyboard only works for 1 player.
If using x360ce did you also try installing the DInput.dll Plugin (required for some games) It's on the github under the download section -- https://github.com/x360ce/x360ce
Download
Digitally Signed Application v3.3.6.0 (2018-07-06) and Libraries 3.4.1.1357 (2015-08-27)
32-bit Download - x360ce.zip - for 32-bit games
64-bit Download - x360ce_x64.zip - for 64-bit games
DInput.dll Plugin (required for some games):
32-bit Download - dinput_x86.dll - for 32-bit games
64-bit Download - dinput_x64.dll - for 64-bit games
arquillos
« Reply #4 on: December 18, 2018, 11:39:03 pm »
Iīll try with this "dll" and report back
Thanks JDFan !
arquillos
« Reply #5 on: December 19, 2018, 03:27:41 pm »
Tried both 32 and 64 DInput.dll versions. No luck :(
