Author Topic: WG7487 cap list with volt and location  (Read 1535 times)
perjmolsen
  • Last login:December 08, 2022, 04:09:06 am
  • I want to learn, and try.. I NEWER give up :)
    • My gameroom
« on: December 17, 2018, 04:39:43 am »
Hi
I want to give my Terminator 2 chassis (WG7487) an cap kit overhaul.
The colors are not so bright - ii have tried to adjust but i do not seem to get it perfect.
But i am having problems find a cap list with placement of caps and volt ratings. (I have looked in the cap lists for mouser but could not find a list)
The reason that i want a list with volts and rating, is that i assume that one of the caps that currently are in the board is not the correct uf, so i want to be sure that this is the only one.
The wrong uf cap i think is C45 its a 47uf 35V I think that the correct uf is 470uf.
So if any can provide me with a cap list it would be great.  ;D
« Last Edit: December 17, 2018, 04:41:40 am by perjmolsen »
