Author Topic: Rowe AMI TI-2 Selection Problem, Stop Paw's jumping selection pins, 1100 mech.  (Read 3111 times)
Mike In Jax
  • Last login:February 16, 2019, 10:34:02 pm
HELP, HELP, HELP!
On my Rowe TI-2 I have an almost (9 out of 10 times) constant problem in the selection portion of the mech.
After selection is made (any and all selections) and the scan wheel plunges the pin through the pin wheel assembly , the now rotating Stop Switch Assembly locates the selected pin.
NOW what happens is the stop paw hits the pin, MOMENTARALLY tripping the stop micro switch ( I know this because at the same time the solenoid that pushes up the spindle try's to fire), instead of the paw staying on the pin, it jumps over the pin.
I have checked & cleaned all switchs, slip rings, wiper arms.  Also replaced both relays on the mech.
AND IT'S DRIVING ME CARZY!!  lol
Can anyone help??  Thanks a lot & I hope everyone has a great holiday season.
« Last Edit: January 03, 2019, 09:07:23 pm by Mike In Jax »
Mike In Jax
With some very good help from a real juke box mechanic, (not me).
The main problem was a worn "sprag" gear in the "Magazine Motor Detent Assembly".  I found a good used one on line, replaced it and set the gap adjustment at .020,  Now it's working great,
