Author Topic: 31khz Arcade monitor with emudriver and groovymame (Sanwa 29e31s)  (Read 3584 times)
flybynight
  • Last login:July 12, 2025, 08:20:47 pm
Would an expert be able to sanity check what I'm doing here.
I've a sanwa 29e31s tube/chassis for testing a "31khz only" setup. Not going to talk about the spare tri sync rodotron666 chassis,. just the sanwa with native res of 640x480.
The graphics card is a radeon 4800 and emudriver 2.0 all installed on windows 10.
1. With Arcade31KhzHiRes and user_modes.ini applied, the desktop looks great and Windows display settings offers very high resolutions of 1280x960 & 960x768 (no 640x480 in the drop down though but it's probably there under the advanced "list all modes" section).  I'm very happy with 1280x960 in the OS as it fits so much on the screen and I don't notice the interlaced flicker.
2. With Arcade31KhzHiRes and "user_modes_super.ini" applied (Super Resolutions), the desktop OS setting goes completely distorted squeezed horizontally. Windows display settings only offers super resolutions of 2560x960; 2560x800 & 2560x768 (I think, can't read them 100% on the screen). I blindly navigate into Advanced display settings then "List all modes" and there I can select 640x480 to finally see the OS desktop again with large icons.
Q's:
a) Does the above sound right? Why can't I get the nice 1280x960 in the OS when I apply user-modes_super.ini?
b) Am I just wasting my time with using emudriver and groovymame on a 31Khz Arcade screen and instead is it recommend to go 640x480@60 for everything? I must say that when I ran street fighter in groovymame as a test, it ran a super resolution like 2560x446@60hz and with scanlines enabled it looked very like it does on the 15Khz hantarex. Is this only in my mind?
« Last Edit: December 15, 2018, 11:25:58 am by flybynight »
Deathblow81
  • Last login:April 24, 2024, 01:16:39 pm
Re: 31khz Arcade monitor with emudriver and groovymame (Sanwa 29e31s)
« Reply #1 on: June 05, 2023, 04:57:17 pm »
Bump!
I'm trying to use the same setup with groovyarcade, did you solve this?
  • Online Online
  • Last login:Today at 01:30:27 pm
« Reply #2 on: June 07, 2023, 01:09:26 pm »
If you're using GA, set the monitor preset to arcade_31 and everything should be automatic.
Deathblow81
« Reply #3 on: June 12, 2023, 09:48:41 am »
Ah Calamity!
I've literally spent days at this desk trying setup an old Pc for my Naomi cab....
Started with the intention of 64bit win xp, could only find professional x64 which is funky apparently for drivers (tried 5er update pack too).. I couldnt get vmmaker to install properly.
Went to win7 for simplicity, I have vmmaker installed and functioning, was going to try an use Atom-15 to keep things safe, but figure to hot switch?
Currently setting up groovyarcade and roms.
You mention just plugging in the latest GA?
I wanna play Cps2-Cps3 and some streetfighter ex2, maaaaayyybeee MvC2 if I'm lucky
I'll have a look.
Big thank you for the work you put into this project! :notworthy:
Youre helping a lot of us get the most out of our cabs  :notworthy:
