Author Topic: Video Noise on any monitor connected to PC  (Read 1914 times)
nipsmg
  • Last login:October 21, 2025, 01:54:35 pm
  • ROONEY!! ERRGH!!
    • Arcadia
« on: December 04, 2018, 08:45:52 am »
I recently modded a TV set for RGB and am connecting to it using a video card and crt_emudriver.  Yesterday I noticed some pretty severe noise and wavy lines on the picture.  I had initially figured it was due to unshielded wiring used to mod the TV, and maybe the flyback was causing some issues.   So I plugged an LCD monitor into the integrated graphics (separate video card) and saw the same exact pattern.   The pattern persists on the LCD attached to integrated VGA when I completely disconnect the CRT.
Any idea what would cause that?
I took a video.  You can see the noise somewhat, but it is much more pronounced in person.
Suggestions?
buttersoft
  • Last login:Today at 12:19:59 am
  • Is running at 15kHz
Re: Video Noise on any monitor connected to PC
« Reply #1 on: December 04, 2018, 07:15:06 pm »
Assuming we're not looking at what appear to be physical marks on the screen above and to the left of the windows logo in your vid...
I would guess at interference, and if the CRT is not only disconnected but powered down, it'll be power related. Do you have another powersupply you can try? Even a cheap, low powered one would be fine to try with your GPU unplugged.
big10p
  • Mmmm, arcade classics!
« Reply #2 on: December 05, 2018, 07:49:01 am »
Can't really see anything in the vid. Almost certainly power related or a ground loop. Need to know more about exactly what your setup is.
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #3 on: December 05, 2018, 09:57:10 am »
I'm 90% sure it's bad PSU.  I'm able to alter and even elminate the noise by manipulating the cables coming out of the PSU. There's something bad happening there.   Just ordered a new modular PSU (and some new VGA cables to be on the safe side), both will be here tomorrow.
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #4 on: December 11, 2018, 05:12:45 am »
Quick update:
Confirmed.  Bad PSU.  Replaced with new PSU, picture clean and stable.
