Author Topic: Anyone use those IDE or SATA to SD card adapters?  (Read 1675 times)
Osirus23
« on: November 20, 2018, 01:18:00 pm »
Have a couple cabs and other PCs from the early 00s and I was thinking about picking up some of those adapters that let you use an SD card as a hard drive through an IDE or SATA connection. Anyone use these? Looking for recommendations or feedback. Amazon and eBay searches return a ton of results.
keilmillerjr
  • Web Developer.
Re: Anyone use those IDE or SATA to SD card adapters?
« Reply #1 on: November 20, 2018, 03:42:11 pm »
I have not. I have a modded Dreamcast IDE -> CF. People have an issue booting from SD. Not sure if the same applies for your scenario, but look into it.
  • Last login:Today at 01:06:53 am
« Reply #2 on: November 20, 2018, 03:52:44 pm »
I've got one in my ps2.  Seems to work pretty good and it wasn't particularly expensive.
Titchgamer
« Reply #3 on: November 20, 2018, 04:56:17 pm »
I went through a ton of different options trying to convert my a51:S4 cab.
My advice is google search your specific cab first!
Some cabs will accept adapters some wont!
Mine would not accept a IDE to SD/CF adapter but a regular A51 cab will.
I did get a flash solution for mine in the end that consisted of using a IDE to SATA adapter then using a SATA memory module which works perfect.
