Author Topic: Upgraded groovyMAME/CRTemudriver; now Mortal Kombat games don't look as good  (Read 3492 times)
DaddyLongLegs
  • Last login:October 11, 2021, 02:23:36 pm
Hello!
I was on an older groovyMAME and just updated to the latest. I also saw there was a newer version of CRTemudriver so I decided to update that too.
Most games like Killer Instinct and Street Fighter 2 look perfect (320x240 on my Wells Gardner low res CRT). However, now all of a sudden all the Mortal Kombat games are way fuzzier than they used to be.
This is what I am getting when I boot those games up:
I am assuming this has something to do with groovyMAME/switchres trying to make adjustments since those games are a little "higher res" than the standard resolution. However, I don't mind a little bit being cut off the top and bottom if it means the image will be razor sharp.
How do I get the games to use what they were when they looked razor sharp? I would try to google/search this myself but I wouldn't even know what to type in!
Thanks so much in advance for any help you can provide!
Calamity
  • Moderator
  • Last login:Yesterday at 10:59:40 am
  • Quote me with care
You didn't create the required modes. You probably want to use super resolutions. Check this.
Steps to create a log:
DaddyLongLegs
Thank you!
I have to do this every time I upgrade mame?
Calamity
  • Moderator
No. You have to do that when you upgrade CRT Emudriver.
