November 30, 2025, 08:09:00 am
You'll probably have better luck with the one based on Crimson 16.2.
More details may help...What version of Windows?What version of GroovyMAME?What kind of monitor did you pick when installing CRT EmuDriver 2.0?etc...Did you try starting with a freshly un-zipped copy of GroovyMAME downloaded from the official location with no modifications?
Make sure you have the latest DirectX 9 installed. It can't hurt...https://www.microsoft.com/en-us/download/details.aspx?id=8109
This is odd. Can you see the same error in VMMaker? When you launch VMMaker, it will report something about ADL initialization. Is there an error in there?The other Switchres error is normal, it's caused by the ADL error.
Go to C:\Windows\System32, copy the file named atiadlxx.dll and paste it inside GM's folder, then run GM and see if it still shows the same error.
Already had added that dll file along with atiadlxy.dll long ago.
Quote from: planexcvs on October 29, 2018, 12:19:36 pmAlready had added that dll file along with atiadlxy.dll long ago.Why? Did you add those in order to attempt to fix this issue or *before* the issue?
