Author Topic: Monitor is a little shaking, on one site of the screen.  (Read 5115 times)
ger
  • Last login:November 08, 2022, 02:54:34 pm
« on: October 06, 2018, 03:10:17 pm »
Hello,
I have been reading some topics, But can someone point me in the right direction?
I live in the netherlands, So if it need a recap Where to buy?
Thanks in advance.
Greets,
Ger
« Last Edit: October 06, 2018, 03:21:55 pm by ger »
ger
Re: Monitor is a little shaking, on one site of the screen.
« Reply #1 on: October 10, 2018, 02:21:44 pm »
Can someone give me Some advice Please?
Greets
Ger
grantspain
« Reply #2 on: October 10, 2018, 06:27:21 pm »
make/model of monitor
is there any ballast or other source of electromagnetic influence near the side that has the issues
do you have a video of the problem
ger
« Reply #3 on: October 10, 2018, 07:03:10 pm »
Hai,
No balast or EFI.
The video is in the first post.
You Can see the srewdriver(not magnatic) on the left side of the monitor. Image is shaking. On the right side not.
Tnx in advance!
grantspain
« Reply #4 on: October 11, 2018, 02:21:21 am »
the horizontal hold is right on the edge of adjustment, is this a hantarex polo?
ger
« Reply #5 on: October 11, 2018, 02:57:36 pm »
Hello,
Thank you for your reply.
Tommorow I can check for sure.
I think it is not a hantrax.
Can you see it ?
Greets
Ger.
grantspain
« Reply #6 on: October 11, 2018, 05:36:37 pm »
looks like a ---smurfy--- kortek clone, whats that big box of shite next the deflection coils?
ger
« Reply #7 on: October 12, 2018, 01:43:03 am »
So it is trash
That box is the Power supply to the pcb game. And some switchbox for the cabinet itself.
grantspain
« Reply #8 on: October 12, 2018, 02:25:04 am »
disconnect the degauss coil and move that box away from the deflection coil- see what happens
ger
« Reply #9 on: October 12, 2018, 04:10:05 am »
WoW youre the man;-)
The degaus, makes a very little diference.
The big black box is causing the big shake.
I think I will buy a new Power source.
Is iT a problem if I dont connect the degaus?
Thanks in advance.
Ps this is the tube.
« Last Edit: October 12, 2018, 04:52:14 am by ger »
grantspain
« Reply #10 on: October 12, 2018, 06:30:26 am »
you can plug back in the degauss
that box is just too close to the deflection coil
ger
« Reply #11 on: October 12, 2018, 07:00:49 am »
Thank you for the Solution.
Greets Ger.
