Author Topic: Golden Tee 2005 boot error (error code 3)  (Read 3903 times)
negzero
  • Last login:November 05, 2018, 03:45:45 pm
« on: September 28, 2018, 02:36:03 pm »
Hey guys. Trying to get my golden tee 2005 up and running. I've got a green board and it recently started giving me an error code 3. It powers on, runs through initial diagnostics and then poof, error code 3 before loading the game.
I've reseated all cables / chips / video card as well as tested it without a HDD (and I get a missing HDD error). Any idea what might cause this? Since I'm seeing video / etc. I'm thinking it's either the mother board or the HDD. Doesn't make sense it would be the PSU if it's getting this far.
Thanks in advance.,
negzero
Re: Golden Tee 2005 boot error (error code 3)
« Reply #1 on: September 30, 2018, 08:59:40 pm »
Nobody? :(
lilshawn
  • Last login:November 26, 2025, 03:26:23 pm
« Reply #2 on: September 30, 2018, 10:41:58 pm »
check your +5v on the board. you'll want it about 5.10 to 5.15 test it on a DIP chip on the board itself like the boot rom or one of the security chips.
voltage will be + and - on opposite corners of the chip with the positive opposite side of the chip from pin 1 and negative on the row all the way down from pin 1
negzero
« Reply #3 on: September 30, 2018, 10:51:57 pm »
That's been a known cause of a boot code 3 on screen? Interesting. I was thinking it might be a corrupt / dying HDD. I'll pull out the multimeter and give it a look.
lilshawn
« Reply #4 on: October 05, 2018, 04:37:04 pm »
could be either or. these boards a pretty sensitive in their voltages. all kinds of weirdness happens if the voltage is low. i wouldn't discount a failing HD either though. if it's still original, i'd look into replacing it.
be sure your eagle boot rom is the latest version, or a new drive will fail to boot.
negzero
« Reply #5 on: November 05, 2018, 03:46:42 pm »
Tested / adjusted voltage on the chip as you recommended. Still failed. So I ordered a boot rom and drive and replaced the old disk with a CF drive. We're back up and running! Thanks for the advice. Was nice to rule out the PSU before shelling out for a drive :)
