Author Topic: Demulshooter with Mamewah (or similar command based frontend)  (Read 1888 times)
Shinobis Shinpads
  • Last login:March 02, 2021, 08:50:08 am
« on: September 27, 2018, 06:08:12 am »
Hi guys,
I'm trying to get Demulshooter running with my old Mamewah. At the moment I'm testing with Model 2 and everything works as it should outside of Mamewah. With Maemwah, usually if I want to run a program before I will add it to the pre_emulator_app_commandlines section. In this case I add it to a specific game.ini so it only works for that game (in this example I've used vcop). So my code I've put in is as follows;
pre_emulator_app_commandlines                                 C:\DEMULSHOOTER\DemulSHooter.exe -target=model2 -rom=vcop
emulator_commandline                                        C:\DEMUL\EMULATOR.exe "[rompath]\[name].[romext]"{nodosbox}{nosafelaunch}
post_emulator_app_commandlines
The problem is Mamewah crashes if I attempt to load virtua cop, so I'm wondering if there's something wrong with how I add my standard Demulshooter command line (which is exactly how I would type it in cmd) to the mamewah.ini. If I remove pre emulator part the emulator runs as it should, just without the Demulshooter configuration obviously. Anyone have any ideas?
Shinobis Shinpads
Re: Demulshooter with Mamewah (or similar command based frontend)
« Reply #1 on: September 28, 2018, 03:39:29 am »
I know it's an old front end,but does anyone still use mamewah or know of someone or a forum that does? There's not a lot on the internet dealling with mamewah these days  :(
Shinobis Shinpads
« Reply #2 on: October 02, 2018, 09:51:12 am »
Given the hefty amount of replies I'm not sure that anyone cares, but went for a batch file in the end to sort it!
Ian
  • Last login:September 26, 2021, 01:50:35 am
« Reply #3 on: October 02, 2018, 05:27:08 pm »
Yeah no idea... I just wanted to comment that you have one of the best user names ever.
That is all.
