Author Topic: Real 4ways or Joystick Restrictors?  (Read 1719 times)
GGKoul
  • Cheesecake Apprentice
« on: February 06, 2004, 11:57:33 am »
I'm looking at redoing my 4 ply control panel.
As I want to add 4 - 4ways joysticks to my control panel to play "Karate Champ".
So my question is:
Do I add a 2 - 8 to 4 way switch joysticks with 2 - 4ways only? (IE: Supers)
Or
Do I keep my 4 - 8 ways Competition joysticks and buy 4 way Joystick Restrictors?
Any thougths you have will be appreicated.  As I'm not sure which will be the ideal step-up.
-GGKoul
NoOne=NBA=
Re:Real 4ways or Joystick Restrictors?
« Reply #1 on: February 06, 2004, 03:10:01 pm »
I personally would go with (4) restricted 8-ways.
That will let you play 2-P double stick games like Smash TV; and, with strategic button placement, can get you a 3 or 4-P CP as well.
It's more costly, but I think the versatility is worth it.
Just make sure the other 3 guys shower before they come over to play.
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: February 06, 2004, 03:14:42 pm »
So my question is:
Or
-GGKoul
Supers are not very good 4-way joysticks, not restricted, and not easy to swap.  (I wouldn't want to have to get under the panel, pop off an E-clip, catch/find it, flip over the actuator, and reinstall the E-clip and close the panel, just to switch from Twin Cobra to Karate Champ.
The Oscar restrictors are a good solution for this.
There is also the Prodigy from www.groovygamegear.com and the T-Stick Plus from www.ultimarc.com which can be switched from above the panel.
Or the Omni-Stik (www.groovygamegear.com) or the J-Stick or T-Stick or E-Stick from www.ultimarc.com.
Basically, it comes down to what kind of feel you like for 8-way and 4-way games. (and what kind of look you want for your panel.)
Comps and J-Sticks have a comparatively long throw, but J-Sticks have a softer spring.
The other sticks all have a shorter throw which is better for Pac-Man type games but maybe not as good for fighters.
FWIW.
GGKoul
« Reply #3 on: February 06, 2004, 03:17:33 pm »
I decided to get the T-Stik 8/4 ways from Ultimarc.
Now I have to redesign my control panel so I can fit 2 more joysticks on my 4 player panel.
As well, I want add 2 rotary joysticks....
Apollo
    • Eight Bells
« Reply #4 on: February 06, 2004, 06:25:53 pm »
Be careful, I can sense a Frankenpanel in your future.
