Author Topic: Gamepad not working in Maximus Frontend  (Read 7877 times)
jpeterson101
  • Last login:September 07, 2018, 11:40:25 pm
« on: September 07, 2018, 11:40:25 pm »
I have been using emulators for a long time. I am using a Bluetooth Gamepad at it works perfectly when configuring the Maximus preferences. It also works inside of MAME when I launch it from Maximus. However when I am in the front end selecting games it does not work  :-\. I confirmed the preferences stuck. I tried multiple Gamepads no luck. Please let me know what I am missing, Thank you!
viking245
  • Last login:June 12, 2024, 10:39:18 am
Re: Gamepad not working in Maximus Frontend
« Reply #1 on: September 08, 2018, 01:47:52 pm »
Did you map the Gamepad controls under Setup 1?
Preferences
Controller
Setup 1
This can be tricky because how MA will 'jump' around.
With the mouse, click ONCE in the space next to "Up".  Press Up on your controller. It will automatically 'jump' to the next field, "Down". Press Down on your controller...etc.
You may not want to map "PageUp" and PageDown".  Just mouse click once in the "Select" field when it gets to that spot.... and so on.
When done click Save and call it what ever you want.  If you click close instead, it will ask if you want to save the layout which worked great when I screwed it up and didn't want to (auto) save.
