Author Topic: Retroarch and CRT Emudriver  (Read 4530 times)
porkins
  • Last login:September 05, 2018, 08:21:21 pm
« on: August 28, 2018, 12:13:26 pm »
I have looked, and found old posts on this subject, but I was hoping somebody had some solid instructions for the current software releases.
I have a Radeon HD 6450, and am using the CRT Emudriver 2.0. I have also installed the latest Retroarch 1.7.3. I am configuring this machine in my office on an LCD monitor before plugging it up to my arcade CRT through the I-Pac I have been using.
How do I configure Retroarch to give me the most accurate, original resolutions? I am using GroovyMame for arcade, so Retroarch is only being used for consoles. Specifically, Atari2600, NES, SNES, Genesis, Sega CD, Turbografx-16, and Turbo CD.
Thank you!!!!
androtaz08
  • Last login:October 09, 2024, 07:17:01 am
Re: Retroarch and CRT Emudriver
« Reply #1 on: August 28, 2018, 03:18:35 pm »
The newer version of Retroarch have a crt emu driver option.
retrorepair
  • Last login:July 06, 2025, 06:47:43 pm
« Reply #2 on: August 28, 2018, 05:53:22 pm »
To elaborate, you have to turn on advanced options before you can see CRT options.
My arcade racing setup:
My Youtube Channel: http://www.youtube.com/user/RetroRepair
My Twitter: http://twitter.com/retrorepair
porkins
« Reply #3 on: August 29, 2018, 09:48:50 am »
Ok. So I go to Video, and turn on "Show Advanced Settings", and then I see the options for "CRT SwitchRes" and "CRT Super Resolution". I turn ON CRT SwitchRes.
What other settings should I change from default to get the best results? Probbaly turn OFF Bilinear Filtering. Anything else?
Thank you!!!
retrorepair
« Reply #4 on: September 01, 2018, 05:15:51 pm »
This is probably a better question for the libretro forums to be honest, this isn't much to do with groovymame other than using crtemudriver.
But yes, any filtering should be off
