Author Topic: Streets of Rage Remake 240p force vsync?  (Read 5779 times)
cyb
  • Last login:November 28, 2025, 06:54:51 pm
« on: August 25, 2018, 12:23:19 am »
Figured this'd be the best place to ask. Streets of Rage Remake supports 240p with CRT Emudriver. It looks wonderful but it has screen tearing. The game has a vsync option but as soon as you activate it, the game switches to "2x" mode which makes it output in 480i. Are there any programs out there that could force vsync on 240p mode?
buttersoft
  • Last login:Yesterday at 07:16:55 pm
  • Is running at 15kHz
Re: Streets of Rage Remake 240p force vsync?
« Reply #1 on: August 26, 2018, 07:16:11 pm »
The only thing i can think of is to try installing Catalyst Control Center. This is normally part of the AMD drivers, and crt_emudriver used to have trouble with it, but i think it's fine to use now. Using CCC you try to enable v-sync globally and see what happens. It's probably not going to work though.
cyb
« Reply #2 on: August 26, 2018, 09:41:26 pm »
I tried installing CCC but it refused to start. Bummer.
  • Last login:Yesterday at 05:20:14 pm
« Reply #3 on: August 29, 2018, 07:54:15 am »
If you're using CRT Emudriver based on Crimson 16.2.1 try this installer.
KoolKolo
  • Last login:November 03, 2020, 11:15:32 am
« Reply #4 on: October 11, 2020, 06:36:25 pm »
Hi cyb,
Where you able to fix the Problem?
cyb
« Reply #5 on: October 12, 2020, 01:30:06 am »
Hi cyb,
unfortunately I never figured it out. :(
psakhis
« Reply #6 on: October 12, 2020, 04:36:04 am »
This game isn't directx or opengl.. i think it's windows xp tested (vsync on sdl) and doesn't work on w7 and above.
Unfortunately source code is closed.
