Author Topic: Track & field New Build  (Read 2636 times)
crom8971
  • Last login:May 22, 2022, 01:03:32 am
« on: August 14, 2018, 12:46:15 am »
Hi all
Looking at building a Track and Field solely dedicated to this game and anything game that can use the same button configuration.
I'll run it with a Raspberry Pi
How do I set up the controllers? 4 x player buttons, 2 x set of run buttons (4 buttons) and 2 jump buttons
can i use the ipac 4?
Thankyou to all that can help.
Yes! I'm a noob at controller configuartion, but just love playing this game with my 12 year old boys.
matsadona
Re: Track & field New Build
« Reply #1 on: August 14, 2018, 12:00:10 pm »
Go for the 4 player cocktail cabinet! Always a success at any party  :cheers:
And with the extra bottom it is good for stand up playing and no need to sit down.
I built a replica a couple of years ago and it was totally worth the time and money spent - http://forum.arcadecontrols.com/index.php/topic,119107.msg1261623.html#msg1261623
By the way, an Ipac2 is good enough since it has 32 inputs, and you will only need 16 of them (with a 4 player setup).
« Reply #2 on: August 14, 2018, 01:35:31 pm »
Use leaf switches.
crom8971
« Reply #3 on: August 14, 2018, 11:31:11 pm »
Cheers for the information, I suppose my main question is that I want to try and build a cabinet similar to the attached picture, i would rather a stand up than sit down.
I'm using raspberry pie to run the program, how do I get player 3 & 4 button working? or attached to an ipac2?
  • Last login:Yesterday at 04:34:38 am
« Reply #4 on: August 15, 2018, 08:34:24 am »
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
« Reply #5 on: August 15, 2018, 08:40:46 am »
I don't understand why you're asking about player3/4 buttons, when that cab style can only accommodate 2 players (just).
« Reply #6 on: August 15, 2018, 08:46:39 am »
You can play 4 players. 2 players at a time in the running events. 1 at a time for the other events. You only need 2 sets of controls. That is the version I am familiar with. Is there another version out there?
big10p
« Reply #7 on: August 15, 2018, 08:50:30 am »
Ah yes, you're right. I had it in my mind that 4 players could play some events simultaneously. :/ Bit of a brain fart there.
  • Last login:Yesterday at 09:03:41 pm
« Reply #8 on: August 15, 2018, 09:35:52 am »
The I-Pac is a hybrid encoder that you can easily assign each input port to output whichever keystroke, gamepad button, or mouse click you want.
For an Upright cab setup, you'll need these 10-12 input ports:
- 6 player buttons (L. Run, Jump/Throw, and R. Run per player position)
- 4 Start buttons (1 each for players 1-4)
- 1 or 2 Coin buttons? (optional)
-- T&F appears to work OK on Free Play. (some games don't)
-- If you want to use Free Play, play-test it BEFORE you start making sawdust.
For P1, the run buttons are Button 1 (L. Ctrl) and Button 3 (Space) and the jump/throw is Button 2. (L. Alt)
In the MAME dipswitch menu, you can set Cabinet to "Upright" (default setting) and Coin A to "Free Play".
Disclaimer: The older versions of MAME used on the RasPi may have different menu options.   :dunno
crom8971
« Reply #9 on: August 15, 2018, 10:26:18 am »
Cheers your a legend
matsadona
« Reply #10 on: August 15, 2018, 12:42:33 pm »
I really recommend that you consider the cocktail table, since it has the optional base and can be an upright, not a sit down, cabinet. It gives every player more space. But of course, it needs more space as well.
https://flyers.arcade-museum.com/?page=flyer&db=videodb&id=2457&image=1
Regarding the ipac2 interface, you can remap the up, down, left, right inputs to the player 3 and 4 buttons, since they are not used in this game anyway.
I have an original Hyper Olympic board in my game, and it runs fine on free play. It would surprise me if the MAME version wouldn't.
