Author Topic: Rowe TI-1 selection  (Read 2351 times)
hman
  • Last login:January 02, 2019, 01:36:36 pm
Rowe TI-1 selection
« on: August 13, 2018, 01:53:50 pm »
Recently having trouble with selections. The plunger is pushing the pin next to whatever my selection is. Sometimes it's pushing the correct pin and the one next to it. Any suggestions?
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe TI-1 selection
« Reply #1 on: August 16, 2018, 07:17:36 am »
Hello hman,
You need to set up the search unit correctly so that the pin pusher is directly over the pin.
Regards
Alan Hood
ami-man
UK
hman
« Reply #2 on: August 20, 2018, 09:22:49 pm »
Adjusted the select coil arm and that took care of it. I guess I was expecting more of an issue then a simple adjustment. Thanks Alan.
