Author Topic: Emudriver 2.0 Failed to create opengl with HD 5000+  (Read 2139 times)
phasermaniac
  • Last login:June 10, 2025, 09:39:41 am
« on: July 30, 2018, 01:01:51 pm »
Hi! I Use an AMD hd 6950, and installed crt_emudriver_&_tools_2.0_beta_13_16.2.1_W.7.8.10-64_nieg.
It recognizes the card right, but I'm getting a cnext error: Failed to create OpenGl context for format...
As I have read and understood, I should not having this problem with a HD 5000+. I'm using composite sync, maybe a problem?
Once installed, the driver runs fine, I can play groovymame at correct resolutions and other emulators too, but I'm having problems with some ttx games
« Last Edit: July 30, 2018, 01:04:19 pm by phasermaniac »
Calamity
  • Moderator
  • Last login:Today at 06:08:16 pm
  • Quote me with care
Re: Emudriver 2.0 Failed to create opengl with HD 5000+
« Reply #1 on: July 30, 2018, 01:10:28 pm »
Where exactly are you getting that OpenGL error? Is it when launching Taito games?
Steps to create a log:
phasermaniac
« Reply #2 on: July 30, 2018, 04:35:14 pm »
Hi calamity, I have read a lot about your work,amazing. arent you spanish? From where exactly?
The error shows up before finishing the installation of emudriver
When launching operation ghost, for example, I get "SForWinUtils.cpp SuCreateWindow failed" (windowed), and "SForWinUtils.cpp no Available resolutions" (fullscreen). While it is working in another similar win10 atigpu pc without crt emudriver
phasermaniac
« Reply #3 on: August 07, 2018, 08:25:51 am »
Nobody have this problem? Any advice on this?
