Author Topic: Groovy Arcade - Force csync on everything?  (Read 3547 times)
bumbervevo
  • Last login:April 27, 2019, 02:28:16 am
« on: July 19, 2018, 04:15:39 am »
I'm wanting to run Groovy Arcade on my PVM 14N6U with my HD 4350 via RGBs. I've been working on and off with Groovy Arcade for about three weeks now, trying to get everything (Arch Linux shell, switchres, AdvMENUPlus, GroovyMAME) to use composite sync. I got AdvMENUPlus to output csync by modifying xorg.conf and setting H/V polarities to positive, but that's all I've been able to get working so far. I'm wondering if anyone else is running Groovy Arcade and has a similar setup, and what steps you took to get it running? Thanks!
Calamity
  • Moderator
  • Last login:Today at 08:05:28 am
  • Quote me with care
Re: Groovy Arcade - Force csync on everything?
« Reply #1 on: July 19, 2018, 12:44:48 pm »
That cannot be done with the Linux build. You'd need a modified version of GM to do that. It shouldn't be too hard if you have some experience with C++.
Or you can switch to Windows.
Steps to create a log:
bumbervevo
« Reply #2 on: July 19, 2018, 11:37:50 pm »
Ahh, that's kinda unfortunate. Was looking forward to working with Linux a bit more. Thanks for the quick answer!
Doozer
  • Last login:June 12, 2023, 09:19:49 am
  • Z80 ERROR
« Reply #3 on: July 20, 2018, 02:07:52 am »
Just for my understanding. What is the issue you are talking about? What is/are the required development?
Calamity
  • Moderator
« Reply #4 on: July 20, 2018, 04:59:24 am »
Basically OP wants GM to add the -csync flag to the modelines sent to xrandr.
The easiest way to do this is to hack the existing GM so it forces the -csync flag, in a custom build.
Currently the modeline code does not support a composite sync flag. In Windows csync is enabled as a global option.
Doozer
  • Z80 ERROR
« Reply #5 on: July 20, 2018, 03:19:16 pm »
Enabling CSYNC with libxrandr is not so difficult. Like the HSYNC and VSYNC flags you have to specify CSYNC flag in the call to the creation of the new mode via XRRCreateMode function call.  CSYNC implementation is driver specific but seems available in the radeon module. Here is where mode flags are set in current code version (0197).
xmode.modeFlags  = (mode->interlace?RR_Interlace:0) | (mode->doublescan?RR_DoubleScan:0) | (mode->hsync?RR_HSyncPositive:RR_HSyncNegative) | (mode->vsync?RR_VSyncPositive:RR_VSyncNegative);
Constants are available since v1.2 of the protocol.
+#define RR_CSync      0x00000040
+#define RR_CSyncPositive   0x00000080
+#define RR_CSyncNegative   0x00000100
Calamity
  • Moderator
« Reply #6 on: July 21, 2018, 05:29:30 am »
That's great Doozer.
I guess that fits better in a custom build since Windows doesn't allow to enable csync per modeline.
