Author Topic: FFB Arcade Plugin  (Read 578987 times)
0 Members and 10 Guests are viewing this topic.
PepsiBoy428
  • Last login:November 01, 2025, 08:05:52 pm
Re: FFB Arcade Plugin
« Reply #1040 on: January 20, 2025, 01:59:34 am »
I got a Logitech G923 to replace my G920 as a christmas gift and man, when using San Francisco Rush or Rush The Rock on MAME, the wheel is so freaking loud, I can barely hear the game, I looked up why the wheel is loud on Google and they say to try to turn the vibration down but the plugin doesn't have an option to do that.
« Last Edit: January 20, 2025, 10:38:16 am by PepsiBoy428 »
Fursphere
  • Last login:March 04, 2026, 11:28:16 pm
« Reply #1041 on: January 20, 2025, 01:33:59 pm »
Turn game volume up.
PepsiBoy428
« Reply #1042 on: January 20, 2025, 03:06:23 pm »
Doesn't work, still can't hear the game as the wheel is still louder
Fursphere
« Reply #1043 on: January 20, 2025, 05:32:07 pm »
TURN GAME UP LOUDER
Joking aside, what do you have it mounted to?   Is <thing you have it mount too> vibrating / reverberating / "acting as a speaker" causing it to be louder than it should be?  I used to have a Logitech G27 and it wasn't loud, I just didn't like the gear driven force feedback and how easy it was to overpower. (ratcheting)
PepsiBoy428
« Reply #1044 on: January 20, 2025, 09:16:46 pm »
TURN GAME UP LOUDER
A wheel stand
Fursphere
« Reply #1045 on: January 21, 2025, 09:31:31 am »
Try a solid desk or table or something to see if it improves.
PepsiBoy428
« Reply #1046 on: January 21, 2025, 10:24:42 pm »
I am not able to as my desk is a card table and I cannot clamp it on there sadly.
PepsiBoy428
« Reply #1047 on: January 22, 2025, 07:10:11 pm »
TURN GAME UP LOUDER
Turning the game up louder is not possible for me bc I live with my sister, brother in law, 2 of my nieces and one of my nephews and if I do, they will get mad and tell me to turn the game down.
(I'm autistic and live with my sister, who is my guardian as well)
brandon
  • Last login:December 26, 2025, 08:29:45 pm
  • I <3 arcade games.
« Reply #1048 on: January 22, 2025, 07:12:40 pm »
I think wearing a pair of headphones is your only option
PepsiBoy428
« Reply #1049 on: January 22, 2025, 08:27:51 pm »
The cord won't be able to reach me and I do not have any wireless headphones
PepsiBoy428
« Reply #1050 on: January 22, 2025, 11:09:20 pm »
PepsiBoy428
« Reply #1051 on: January 25, 2025, 02:31:01 pm »
So sadly I'm out of options
Gewargis
  • Last login:March 21, 2025, 12:52:19 pm
« Reply #1052 on: March 13, 2025, 11:11:44 pm »
Playing Daytona Championship USA - NSE and the wheel always has a slight rumble to it (like a car idling) even when in attract mode/menus. I have tried adjusting min force to 0 and even tried 50 but it still remains. Is there another deadzone like option for the ffb? Turning the wheel in attract mode/menu activates the motor as well.
Tekno Parrot 1.0.0.1568
FFB  v2.0.0.53
BFF 7.0.167
Sky25es
  • Last login:November 24, 2025, 12:35:19 pm
« Reply #1053 on: March 17, 2025, 05:46:39 am »
Hi everyone. Does anyone know if the Ffbplugin currently works with Pokken Tournament? I have Windows 10 and an Xbox One controller. Rumble works in the GUI, but not in-game. I've tried every possible revisions and put the DLLs in every Teknoparrot folder. I've also tried Jconfig, but I haven't gotten it to work. Other games do work fine. Thanks.
Gewargis
« Reply #1054 on: March 21, 2025, 12:52:18 pm »
FFB  v2.0.0.53
BFF 7.0.167
I resolved this by increasing the spring deadzone in the BFF application.
Jollywest
  • Last login:Today at 07:59:47 am
« Reply #1055 on: April 19, 2025, 02:13:58 am »
Hi, I’ve been running the FFBPlugin alongside Teknoparrot, and I’m using a Happ active steering assembly with the Immersion FFB board.
I have everything setup and working including the FFB on racing games that support it, but I do have one issue;
Sometimes when I stop playing one game and start another, the FFB stops working. I have to restart the PC for the FFB to start working again.
When the FFB has stopped working, the wheel is still visible in the FFBPlugin GUI but none of the effects work in the test area.
The effects also don’t work in the Immersion Driver software when this happens.
I’ve attached 2 logs produced by the FFBPlugin.
Dead Heat was the first game with the FFB working, and then Outrun 2 was the game played straight after it
when the FFB had stopped working.
Edit > seems to have been solved by unchecking the top option in the attached pic
« Last Edit: April 21, 2025, 06:07:20 am by Jollywest »
Endprodukt
  • Last login:March 04, 2026, 03:30:14 pm
« Reply #1056 on: May 17, 2025, 01:50:32 pm »
Hi
I was wondering if there was a chance to see outputs for more recently running games like Time crisis 2 or point blank 3?
Best regards
Rhyader
  • Last login:July 14, 2025, 04:30:49 pm
« Reply #1057 on: May 27, 2025, 06:29:11 am »
Hi, how to set up ffb plugin in Flycast? Simply copy all ffb files near flycast exe? No options to change in the emulator? Thanks
sergiobiston
  • Last login:June 12, 2025, 10:49:40 pm
« Reply #1058 on: May 27, 2025, 11:05:53 pm »
I downloaded latest FFB plugin and it does have files for Cruisn Blast. However, it does not work in game. Does anyone knows a solution?
Endprodukt
« Reply #1059 on: June 08, 2025, 11:15:32 am »
Read the help file. Stuff goes into ElfLoader2 folder.
Endprodukt
« Reply #1060 on: July 02, 2025, 03:51:38 am »
FFB on Sega rally and Daytona on the latest mame (278) are not working.
Endprodukt
« Reply #1061 on: August 20, 2025, 01:46:05 pm »
So FFB plug-in is abandoned. I'm not a programmer. What are chances we see more recently emulated games (model 2, Konami etc) with FFB support?
buttersoft
  • Last login:March 04, 2026, 09:09:23 pm
  • Is running at 15kHz
« Reply #1062 on: August 29, 2025, 06:43:36 am »
You should go to the TP discord, to Boom's channels, and ask a few polite questions :)
Endprodukt
« Reply #1063 on: September 03, 2025, 11:27:16 am »
Not possible. I'm banned because I gave them feedback they didn't like.
SK91
  • Last login:November 14, 2025, 06:36:53 am
« Reply #1064 on: October 29, 2025, 06:36:40 pm »
I've got some problems running Windows 11 with a Thrustmaster T150 on MAME and Teknoparrot, while MAME might have worked for me some time ago, no combination of old MAME/FFB plugin builds seem to amount to anything anymore. On Teknoparrot there's this problem I've had forever where the FFB will work for a couple minutes, there comes a point where the wheel gets weaker for a few seconds before the FFB cuts out entirely systemwide until I replug the wheel in, I thought this may have been power related, but it works in other games, and turning down the FFB strength by over half resulted in the same thing. It's been driving me insane since I've probably spent over a dozen hours in total spending a whole session I intend to play something for a bit on the odd occasion I pull out my wheel, and it turns into a multi-hour, multi-day troubleshooting session which results in me just playing something else. The cycle repeats pretty much every few months
Endprodukt
« Reply #1065 on: November 04, 2025, 05:24:31 am »
You won't like it but get a more common wheel. I had the same trouble with a t500. T300 fixed it.
SK91
« Reply #1066 on: November 04, 2025, 06:15:24 am »
T150 and T300 use pretty similar drivers, and they're plenty common as a cheaper wheel. Anyway I sorted that out by taking the SDL2.dll from 2.0.0.16 and using it on the latest version of the plugin since an update to SDL after that is what made it stop working properly. Got games on MAME to work with FFB by switching to cabmame
« Last Edit: November 04, 2025, 02:52:02 pm by SK91 »
