Author Topic: 2 Trackballs & 2 Spinners?  (Read 3573 times)
Velvis
  • Last login:July 25, 2021, 12:31:34 am
« on: June 22, 2018, 01:53:15 am »
I have a cocktail mame machine. I want each end to have a joystick, 3 buttons, a spinner and a trackball.
The trackballs are 2" retro arcade usb/ps2 and the spinners are turbo twists 2 one slave/one master.
Is it possible to get this all to work?
  • Last login:Today at 03:03:03 pm
Re: 2 Trackballs & 2 Spinners?
« Reply #1 on: June 22, 2018, 02:28:27 am »
Yes, that list of controls can work together.
You'll need 4 USB ports:
- Keyboard-style or gamepad-style encoder for the joysticks and player/admin buttons
- Trackball 1
- Trackball 2
- TT2 spinners
Windows supports up to 8 axes, the trackballs and spinners use a total of 6.
Enable multimouse so each axis is separate, otherwise Windows will:
- Add changes to Trackball 1 X-axis, Trackball 2 X-axis, and Spinner X-axis and output the sum as a change to mouse X-axis.
- Add changes to Trackball 1 Y-axis, Trackball 2 Y-axis, and Spinner Y-axis and output the sum as a change to mouse Y-axis.
  • Last login:Today at 09:23:52 am
« Reply #2 on: June 22, 2018, 07:03:25 am »
How are you going to fit all of that on a cocktail control panel?
  • Last login:Yesterday at 11:23:23 pm
« Reply #3 on: June 22, 2018, 10:27:29 am »
That’s what I was thinking...
« Reply #4 on: June 22, 2018, 10:37:53 am »
I shouldn't have asked. I know the answer is going to be terrible.
Velvis
« Reply #5 on: June 22, 2018, 11:19:17 am »
Galaga, Ms. Pacman, Tempest, Centipede.....
« Reply #6 on: June 22, 2018, 11:36:04 am »
I knew I was going to regret it.
KenToad
  • Last login:January 27, 2026, 02:41:03 pm
  • Flap Flap Flap
« Reply #7 on: June 23, 2018, 02:22:57 am »
I have a trackball and two spinners and I often have a normal mouse connected. Occasionally, when booting, the numbers assigned to each mouse will change and I have to remap the controls. Maybe someone has a simple solution, but it is an irritation when running multiple numbered devices with MAME.
« Reply #8 on: June 23, 2018, 02:27:51 am »
Have you tested it? The trackball and spinner more than likely will both be active at the same time, so when you ay a rounding game of Tempest or Centipede and accidentally hit the other control, it’s going to mess up your movement and your game. I speak from experience.
Velvis
« Reply #9 on: June 23, 2018, 03:15:41 am »
Not yet, but I was planning on configuring it as players 3 & 4 in MAME so the trackball wont interfere.
Mr. Peabody
  • Last login:November 11, 2025, 07:08:52 pm
« Reply #10 on: June 27, 2018, 03:36:25 pm »
Make it wider? People seem stuck on that size for the end panels, but will easily make the 2P panel on the broadside the length of the cabinet.
