Author Topic: Remapping for Neo Geo  (Read 7441 times)
vaderag
  • Last login:May 07, 2025, 11:33:07 am
  • Building my own cab :)
« on: June 08, 2018, 12:48:11 pm »
I have an 8 button layout and in general I have the following setup which works for most MAME games:
1 2 3 7
4 5 6 8
However, for Neo Geo (which I have as a separate system in RL and Hyperspin) I really want 1 2 3 4 (A B C D) on the top row
I have tried setting RL to use AHK to remap the two keys for P1 and P2, works in test but in game doesnt do anything
I could remap every game for the neogeo in MAME, but is there an alternative?!
Re: Remapping for Neo Geo
« Reply #1 on: June 08, 2018, 01:00:02 pm »
isn't there like a neogeo.ini/cfg you can change so it applies to all neogeo games?
tons of Neogeo games don't even use D, so you'd really only have to manually map like 20 games.
vaderag
« Reply #2 on: June 08, 2018, 01:16:29 pm »
Hmm... never thought about that - maybe that is the answer... will take a look
Also never realised that many didn't use D, so worst case that doesnt sound atrocious either!
vaderag
« Reply #3 on: June 08, 2018, 01:18:04 pm »
Update - not seeing a neogeo.ini :(
  • Last login:Today at 06:45:10 am
« Reply #4 on: June 08, 2018, 01:48:38 pm »
It was a ctrlr file.  I was reluctant to answer since it's been so long that I don't remember the particulars.
See the X-arcade ctrlr file here: https://support.xgaming.com/support/solutions/articles/12000003054-advanced-mame-configuration-config-file-download
It has a separate section for neo geo.  You can probably just copy and paste that to the default cfg file in the ctrlr folder.
<system name="neogeo">
<input>
<port type="P1_BUTTON1">
<newseq type="standard">KEYCODE_C          OR JOYCODE_1_BUTTON1</newseq>
</port>
<port type="P1_BUTTON2">
<newseq type="standard">KEYCODE_LSHIFT     OR JOYCODE_1_BUTTON2</newseq>
</port>
<port type="P1_BUTTON3">
<newseq type="standard">KEYCODE_Z          OR JOYCODE_1_BUTTON3</newseq>
</port>
<port type="P1_BUTTON4">
<newseq type="standard">KEYCODE_X          OR JOYCODE_1_BUTTON4</newseq>
</port>
<port type="P1_BUTTON5">
<newseq type="standard">NONE</newseq>
</port>
<port type="P1_BUTTON6">
</port>
<port type="P1_BUTTON7">
</port>
<port type="P1_BUTTON8">
</port>
<port type="P2_BUTTON1">
<newseq type="standard">KEYCODE_CLOSEBRACE OR JOYCODE_2_BUTTON1</newseq>
</port>
<port type="P2_BUTTON2">
<newseq type="standard">KEYCODE_W          OR JOYCODE_2_BUTTON2</newseq>
</port>
<port type="P2_BUTTON3">
<newseq type="standard">KEYCODE_E          OR JOYCODE_2_BUTTON3</newseq>
</port>
<port type="P2_BUTTON4">
<newseq type="standard">KEYCODE_OPENBRACE  OR JOYCODE_2_BUTTON4</newseq>
</port>
<port type="P2_BUTTON5">
</port>
<port type="P2_BUTTON6">
</port>
<port type="P2_BUTTON7">
</port>
<port type="P2_BUTTON8">
</port>
</input>
</system>
« Last Edit: June 08, 2018, 01:54:19 pm by BadMouth »
« Reply #5 on: June 08, 2018, 01:53:16 pm »
There isn't until you make one.  It replaces mame.ini settings though, which IIRC do not include key mappings.
See my post about the ctrlr folder above.
Back when I set up HLSL on v.146, I made a neogeo.ini with the HLSL settings I wanted to use on all the Neo Geo games.
You can also make vertical.ini and horizontal.ini files to have different settings for those particular games.
.....at least you could back when I set everything up.  Things may have changed by now.
vaderag
« Reply #6 on: June 08, 2018, 02:06:48 pm »
Thanks. Putting the kids to bed right now so will try that config in a bit or tomorrow!
Sent from my Mi A1 using Tapatalk
Titchgamer
« Reply #7 on: June 08, 2018, 02:25:51 pm »
I would use a separate emu for neo geo games.
Can configure however you like then.
vaderag
« Reply #8 on: June 08, 2018, 02:27:32 pm »
Just a copy of MAME or I there a better one?
Titchgamer
« Reply #9 on: June 08, 2018, 02:30:22 pm »
There is a separate emu just for neo geo called Nebula that I use on my cab.
« Reply #10 on: June 08, 2018, 02:52:02 pm »
It's not worth messing with another emulator just to friggin' remap the controls.
FYI, I built a NEO GEO themed cab, so had to do the appropriate button layout.
After playing it a while I came to prefer the default MAME layout to the original one.
It's easier to hit that 4th button with your thumb than moving your ring finger over or using your pinky.
I went back and remapped things so either could be used.
Titchgamer
« Reply #11 on: June 08, 2018, 02:54:33 pm »
I disagree about the emu but I agree with the button layout comment!
I used 3 along the top row for b,c,d and the first of the botton row for a.
vaderag
« Reply #12 on: June 08, 2018, 03:15:14 pm »
Isn't it kind of cheating if you're using an easier layout than the game was built for?! ;)
Titchgamer
« Reply #13 on: June 08, 2018, 03:18:04 pm »
Well my cab has 2 rows of 3 buttons so I couldnt do 4 straight without hassle lol
vaderag
« Reply #14 on: June 08, 2018, 03:22:27 pm »
Valid excuse.
Still gonna try the original layout (when I can get it working)...
Jakobud
  • Last login:November 11, 2025, 01:07:55 am
« Reply #15 on: June 08, 2018, 03:23:24 pm »
On a related note, is there a list somewhere of all the different system-specific INI/CFG files you can create? I don't know what all the different names are.
Titchgamer
« Reply #16 on: June 08, 2018, 03:25:23 pm »
Valid excuse.
Yeah try Nebula works great with all neo geo roms.
Dodgeball is the gonads :D
vaderag
« Reply #17 on: June 08, 2018, 03:38:27 pm »
This would helpful. Looking at the stuff hanging around I'm not convinced that my Neo Geo system isn't AES instead of neogeo (tho this is mostly conjecture...)
« Reply #18 on: June 08, 2018, 04:05:29 pm »
You mean AES instead of MVS? both are "neogeo"
I don't recall all the various system specifics you could name, MAME loves to change ---steaming pile of meadow muffin---, especially if it isn't broken. I was happy I remembered what I did.   As for playing NeoGeo.......I have a 2 slot cab, with a 1 slot mobo with a Darksoft Multi MVS
phulshof
  • Last login:November 06, 2025, 03:43:59 am
    • Pieter's Webpage
« Reply #19 on: June 08, 2018, 04:49:41 pm »
Key configurations are either read from the cfg file or from the ctrlr file you've selected. Easiest is indeed to grab one of the pre-defined control files, set that in your mame.ini file, and adjust the keys accordingly. Several of them (I use the hotrodse) already have a separate key configuration for NeoGeo you can work from.
vaderag
« Reply #20 on: June 09, 2018, 05:30:34 am »
Sorted it by adding a ctrlr file called neogeo following the convention in other files! Thanks :)
keilmillerjr
  • Web Developer.
« Reply #21 on: June 09, 2018, 06:58:04 am »
MVS and AES shared most game titles, and were the same software. Some mvs boards include aes controller ports. MVS was sold as a stand alone machine, and kit. MVS stand-alone machines had two different action button layouts - curved and staggered. AES controllers included an arcade controller, advanced controller, Neo Geo standard controller. All have different layouts - or “bring your own layout” with the MVS kit.
« Reply #22 on: June 09, 2018, 10:50:58 am »
Awesome.
« Reply #23 on: June 09, 2018, 11:27:17 am »
Awesome.
Happy to kind of help :p
