Author Topic: 720 joystick specs?  (Read 2745 times)
ListerD
  • Last login:July 29, 2019, 04:20:39 pm
720 joystick specs?
« on: June 03, 2018, 02:24:50 pm »
Does anyone have the specs on the original 720 joystick, as far as stick length above the control panel, angle, and diameter or circumference of the circular stick travel path?  The only docs I've been able to find are specs on the PCB and I don't have access to an original machine nearby.  I'm planning on trying to build a spinner knob to simulate the joystick since the originals are about impossible to find or prohibitively expensive.  But I would like to get the control as close to the size/angle of the original as possible.  Appreciate any help!
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
Re: 720 joystick specs?
« Reply #1 on: June 08, 2018, 09:54:56 am »
Here are some detailed diagrams:
http://jstookey.com/arcade/720/720man_controller_a.jpg
http://jstookey.com/arcade/720/720man_controller_b.jpg
I took some rough measurements:
2 inches measured to the center of the joystick ball
>> angle of the circular stick travel path?
71.5 degrees (angle of the joystick)
1.5 inches (from the center of the stick at the control panel surface)
Hope that helps!
« Last Edit: June 08, 2018, 09:57:44 am by jerryjanis »
ListerD
« Reply #2 on: June 08, 2018, 06:12:40 pm »
Yes, that's perfect, thank you so much.  I would have been way off on the diameter, going from memory.  Really appreciate you taking the time to answer.  720 is one of my favorite games from my youth.  Do you have an original 720 cab?
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
« Reply #3 on: June 08, 2018, 08:37:24 pm »
No just the joystick.
  • Last login:November 13, 2025, 01:36:49 am
« Reply #4 on: June 08, 2018, 10:27:52 pm »
I’m restoring one. I’m going to do a full rebuild of my joystick.
  • Last login:November 13, 2025, 06:30:55 am
« Reply #5 on: June 09, 2018, 06:29:26 am »
How is that resto going?
« Reply #6 on: June 09, 2018, 12:34:22 pm »
Slow and steady wins the race.
