Author Topic: Neotec 2515C vertical collapse on Hydro Thunder  (Read 3022 times)
Shaybe
  • Last login:March 07, 2019, 10:49:39 pm
« on: June 01, 2018, 09:19:09 am »
A while back I put a new flyback in Hydro Thunder but accidentally swapped the two wire because the colors were swapped from the original. After putting the wires back to how they were supposed to go I was greeted with a horizontal line running across the screen. I found some posts with these good measurements
IC 301 (LA7836)
1:11.6 Vcc
2:4.6
3:5.8
4:0 ground
5:5.9
6:5.3
7:20.0 Vcc
8:2.2
9:1.4
10: 0
11:11.6
12:20.0
13:4.8
IC401 (LA7850)
10: 12v
20: 12v
r117: 125v
r118: 25v
r119: 25v
ZD101: 12v
And then here is what I measured
IC 301
1:11.7
2:158 mV (BAD)
3:5.87
4:0
5:10.76 (BAD? too high)
6:.46 (BAD)
7:23
8:20 mV (BAD)
9:2.6
10: 0
11:.42 (BAD)
12:22.8
13:4.9
IC401
10: 12v
20: 12v
r117: 175 mV (BAD)
r118: 102 mV (BAD)
r119: 12.4 (BAD?)
ZD101: 12v
From a suggestion on another post I replaced IC301, but the vertical collapse remains.
Does anyone have any suggestions of what else I could check?
