Author Topic: Amiberry issue with Keyboard  (Read 4117 times)
Marcoqwerty
  • Last login:October 07, 2025, 08:38:10 am
« on: May 25, 2018, 11:17:50 pm »
Im trying to setup Amiberry, all is working except for the Keyboard not recognized by the emulator.
- I have setup correctly the retroarch.cfg (and it works)
- Link the path of this file under the Amiberry emulator and rescan path
- Check under Input TAB of the Amiberry GUI and it show : Not a Valid Input Controller for Joystick Emulation
Extra check:
- After reading the wiki :
joy0 should be used if you wish to use the emulated 'keyboard as joystick' controller.
I've changed the following line of the whdboot/hostprefs.conf file.
CONTROLLER_1=joy0
;CONTROLLER_2=joy2
;CONTROLLER_3=joy0
;CONTROLLER_4=joy3
;CONTROLLER_MOUSE_1=joy2
;CONTROLLER_MOUSE_2=joy1
;RETROARCH_QUIT=TRUE
;RETROARCH_MENU=TRUE
;RETROARCH_RESET=TRUE
;KEY_FOR_QUIT=F12
;KEY_FOR_MENU=F11
;DEADZONE=33
;STEREO_SPLIT=1
;SOUND_ON=FALSE
;ASPECT_RATIO_FIX=TRUE
;FRAMESKIP=TRUE
Now i' blocked at this point.... anybody have this emu working? (keyboard included)  :dizzy:
