Author Topic: Some ServoStik Questions...  (Read 2784 times)
  • Last login:Today at 04:50:43 pm
« on: May 18, 2018, 11:02:47 am »
How much space do I need under a CP for a ServoStik assuming I bottom mount it?  Thanks.
« Last Edit: May 31, 2018, 06:52:51 pm by javeryh »
05SRT4
  • Check out my Pow Pow
Re: How deep is a ServoStik?
« Reply #1 on: May 18, 2018, 11:23:41 am »
Just measured mine and it was about 1 3/4 inch or about 45mm. I replaced the restrictor plate screws with longer ones so you might be able to do 1 1/2 inch if you want it really snug.
« Reply #2 on: May 18, 2018, 11:33:47 am »
Thanks a lot.  I may need to make some design changes now!  I have about 1-3/4" total right now to work with but probably don't want to cut it that close.
danny_galaga
  • Last login:Today at 05:45:42 am
    • dans cocktail lounge
« Reply #3 on: May 23, 2018, 04:10:35 am »
Worth the effort. I was quite chuffed with mine (",)
« Reply #4 on: May 24, 2018, 10:23:39 am »
yeah - I've read nothing but good things.  I'm probably only going to have 50 or so games in this cab I've been kicking around but it will be a mix of 4-way and 8-way and vertical and horizontal games so this joystick seems like the best solution...
danny_galaga
« Reply #5 on: May 25, 2018, 02:01:33 am »
Worth mentioning that they may need a little attention out of the box. I wrote about mine at the end of this thread:
http://forum.arcadecontrols.com/index.php/topic,132157.msg1521798.html#msg1521798
« Reply #6 on: May 25, 2018, 12:11:57 pm »
Thanks - I'll definitely keep this in mind when I install my stick.  Very helpful!  :cheers:
« Reply #7 on: May 31, 2018, 06:46:01 pm »
So.... the ServoStik is supposed to come with the motor, right?  Mine showed up blank.  The restrictor plate was there but not the motor.
Edit: Never mind. Andy took care of it!
« Last Edit: June 01, 2018, 07:02:09 am by javeryh »
