Author Topic: Pandora Box 4s+ noob  (Read 2914 times)
mprivi
  • Last login:May 17, 2018, 02:13:00 pm
  • I want to build my own arcade
« on: May 16, 2018, 04:26:14 pm »
I was wondering if a Pandora box 4s+ will run on just a 5v power supply? I have an old bartop that only has a 5v power supply to the Jamma. I don;t want to just plug it in with out asking incase i fry or mess something up.
  • Online Online
  • Last login:Today at 12:04:50 am
Re: Pandora Box 4s+ noob
« Reply #1 on: May 16, 2018, 05:11:59 pm »
There are at least two pins (27 and e) that are different between a standard JAMMA pinout (grounds) and the Pandora's Box. (button 6 inputs)
Looks like you'll need a power supply with 12v, too.
Standard JAMMA and Pandora's Box pinouts.  Double check that your pinout matches the second one.
« Last Edit: May 16, 2018, 05:14:56 pm by PL1 »
ArcadeAction
  • Last login:March 03, 2019, 04:35:29 pm
  • I have built my own arcade controls!
    • ArcadeMade.com
« Reply #2 on: May 16, 2018, 05:19:50 pm »
You will need 12v as well. I configured a bar top recently. It does not work with 5V alone.
  • Last login:Yesterday at 07:17:48 am
« Reply #3 on: May 16, 2018, 05:27:22 pm »
There are other multiboards out there that use an IDE power connector.
Grab something like this:
https://www.amazon.com/Warmstor-Drive-Adapter-Converter-External/dp/B076WZ1N4K/
Cut off the end of the wall plug, splice it to the power switch on your cabinet, plug the IDE cable into the board, disconnect the existing power supply in your cabinet.  Done.
