Author Topic: PS2 Guncon2 PCB to Original Namco Arcade Gun mod  (Read 3698 times)
mR_CaESaR
  • Last login:July 04, 2024, 10:40:13 pm
« on: May 04, 2018, 09:39:21 am »
Has anyone here by any chance modded their Namco arcade gun to work with a guncon2 for ps2?
I would love a time crisis cab or a point blank cab, but unfortunately, I just don't have the room or can afford one at present.
The next best thing is to mod my astro city to play ps2 namco light gun games!
Enter my inspiration
I'm now in the process of trying to begin this mode, but before I worry about the solenoid, first things first is to "convert" the Namco gun for the PS2 using the gcon2 pcb!
Looking at the video, it seems pretty "easy" in terms of wiring up the +5v, GND, optical line and trigger line and the gcon2 works with the "namco" optical component without any "mods"
Sourced out a gcon2
Taking it apart is pretty self explanatory and I ended up with the main PCB
Using the trusty multi meter, I found what I believe to be the trigger wire
The GND and +5v
And what I believe is the Optical line
Note, I have removed the optical sensor from the PCB
I connected the following:
  • +5v from the gcon2 pcb to the +5v line of the namco gun (goes to the optical sensor - red)
  • GND from the gcon2 pcb to the GND line of the namco gun (goes to the trigger micro switch and optical sensor - black)
  • Optical sensor line from the gcon2 pcb to the Optical sensor line of the namco gun (white)
  • Trigger line from the gcon2 to the trigger line of the namco gun (blue)
I'm not sure if there's anything else that I've missed, but for the life of me, I can't work out why the namco gun doesn't work. The video appears to show it should work seamlessly but when I try and calibrate the Namco gun on the PS2 (gcon2 calibration screen), nothing registers.
The PS2 definitely recognises the gcon2 and it did work prior to removing the shell and sensor.
I'm hoping someone on here has previously done this type of mod or is very familiar with the gcon.
Any ideas or suggestions?
