Author Topic: Sanyo 14" - Identify RGBS signals?  (Read 2286 times)
rocomat
  • Last login:November 25, 2019, 12:10:13 pm
« on: April 17, 2018, 06:48:14 pm »
Hi!
Can someone help me to identify the RBG and S and Ground signals code? (cable has 5 signals) from this Sanyo 14" cocktail monitor?
I looked at the manual, I can not see RGB or Sync or what is the 5th input, I thing Ground.
Page 3 "E. Connectors" shows the pin numbers and the signal, but who knows the pin numbers from that old connector?  If it would be shown that would help...
Manual: http://files.arcadeinfo.de/Monitore/Sanyo%2014''%20Color%20TV%20Monitor.pdf
There's not print for this cable on the board.
See the white cable with diffent red dots at middle - bottom.
thanks!
« Last Edit: April 17, 2018, 06:54:02 pm by rocomat »
!! Looking for After Burner Deluxe cabinet plastic parts !!
rocomat
Re: Sanyo 14" - Identify RGBS signals?
« Reply #1 on: April 17, 2018, 08:11:13 pm »
Got ist, went to the resistors and this way I could identify the cable code.
buttersoft
  • Last login:Today at 03:32:48 am
  • Is running at 15kHz
« Reply #2 on: April 17, 2018, 08:26:49 pm »
From the top down, was it R, G, B, ground, empty, sync?
