Author Topic: Beginner Help Needed  (Read 4394 times)
MK3U2012
  • Last login:June 08, 2020, 09:04:05 pm
  • Check out my reviews on KLOV
« on: April 15, 2018, 02:12:31 pm »
running mame version .161 paired with rocket launcher and using hyperspin version 1.4 as a front end.
I am capable of successfully loading and playing games through hyperspin. Only trouble is only 341 of the over 8000 games are available to play with the rest being in red. And of the 341 there are many that either start to load and kick back to menu of load into an unplayable game.
Im wondering if either my mame version, romset or both are not complete, working or compatible?
Any help is greatly appreciated and after thoroughly reading the rules im hoping i have not broke any with the above post.
Blake
  • Last login:Today at 01:40:55 pm
Re: Beginner Help Needed
« Reply #1 on: April 15, 2018, 04:20:46 pm »
Based on "8000 games" and this chart, it looks like your ROMset is older than v0.161 (Maybe v0.141?) and is probably missing many BIOS and driver files.
It's usually easier to find a known version ROMset first, then download the matching version of MAME.
If you want to use a "no-nag" version of MAME, get things working with the regular version first or you won't see the useful info telling you why MAME is not working right.
MK3U2012
« Reply #2 on: April 15, 2018, 05:18:57 pm »
sorry for the lack of knowledge when it comes to terminology but what is no-nag and also what would be considered a normal version of mame?
thanks
blake
MK3U2012
« Reply #3 on: April 15, 2018, 05:24:11 pm »
i know the romset was listed as .161 but i guess that could be false.  is there a way to identify for sure?  I would be happy to download a known good romset and match the mame version download but so far im 0-2.
thanks
blake
« Reply #4 on: April 15, 2018, 07:00:45 pm »
"Nag" screens are the info that MAME displays when you launch the game.
- On most games, MAME just asks you to move the joystick left then right to continue.
- On some games, there may be warnings that the emulation is not working right yet.
MAME Devs hate the "no-nag" versions that bypass these info screens because noobs submit bogus/repeat bugfixes like "Simpsons Bowling sound is messed up." which they would have known if they had seen the warning screens.
If you download MAME from the MAMEDev.org site, it will be the baseline "vanilla" version -- newest release here or older releases here.
It probably is 0.161, but it might be incomplete. (deleted non-working games or clones)   :dunno
Assuming that it is a complete set, here are two quick-and-dirty tests that should confirm.
The "What's New" for v0.161 mentions that "Stadium Cross (World, alt)" was added as a new clone.
- If the ROMset contains the file "scrossa.zip", it is v0.161 or newer.
The "What's New" for v0.162 mentions that "Contra (US / Asia, set 3)" was added as a new clone.
- If the ROMset contains the file "contrae.zip", it is v0.162 or newer.
MK3U2012
« Reply #5 on: April 15, 2018, 07:14:27 pm »
so there is no "scrossa.zip"
there is no "contrae.zip" but there is a "contra1.zip"
each of the versions of mame ive download have been from mamedev
For the hell of it i just downloaded .141 version of mame and that seems very odd as it does not even have the mame emblam
thanks
blake
« Reply #6 on: April 15, 2018, 08:29:41 pm »
There's probably some configuration problem with MAME, HyperSpin, or Rocket Launcher.
Have you tried launching MAME without using HS/RL?
MK3U2012
« Reply #7 on: April 15, 2018, 09:41:30 pm »
no i have not given that a shot let me see if theres any change.
thanks
blake
MK3U2012
« Reply #8 on: April 15, 2018, 10:27:37 pm »
well i must be doing something wrong because ive moved my mame setup folder from my c drive to my external hard drive which is where my full romset is located.  then i moved the folder with all the zipped roms into the rom folder of the mame setup and it does not see them.  there is no interface with this version of mame, well i should say a very plain interface that im not very familiar with the commands so i have not been able to get it to search for the rom set.  ill try more tomorrow.
thanks
blake
MK3U2012
« Reply #9 on: April 16, 2018, 02:48:41 pm »
so the .196 romset downloaded successfully and im now showing almost 8 k of games in the green. i still have to reconfigure everything to be able to play them and im hoping to do that tonight. ill keep you posted.
thanks again
blake
MK3U2012
« Reply #10 on: April 16, 2018, 05:08:05 pm »
so as i was configuring i noticed that mame does not launch.  it has a window that blinks quickly and thats it.  no error message, no menu, and nothing loaded.  Im wondering if i need to have a higher .netframework as my vista currently only has 3.5 i believe and sometimes after booting gives me an error message but then moves forward without issues.
Everything is smooth other than that.
thanks
blake
MK3U2012
« Reply #11 on: April 16, 2018, 09:41:37 pm »
so i borrowed another more modern laptop and hooked up the external hard drive and mame popped right up. so at least we verified its a good download.
thanks
blake
