Author Topic: Neo Geo Multi Slot Load Not Working  (Read 2983 times)
brywalker
  • Last login:August 13, 2018, 07:23:56 pm
« on: April 13, 2018, 10:33:00 pm »
Hey folks.
So I have been waiting like 2 years to post this - because I was always thinking the next one would get working for me.
I cannot get this to work. AT ALL. I started trying on .171. Help.
Tried straight in command line mame.exe neogeo -cart1 maglord -cart2 mslug (etc). Tried loading with bios and memory card and without. All have the same outcome.
"maglord" approximately matches the following
supported software items (best match first):
Fatal error: Device Neo Geo Cartridge Slot load <> failed:
If I go straight mame.exe maglord, works perfectly. If I try mame.exe neogeo -cart1 maglord (or whatever rom name) it will just go to the test grid (basically loads the bios).
I haven't tried this on straight mame because I don't care about straight mame for my Neo cabinet.
Config is legit. All paths are fine. This is the only thing that is not working - everything else is flawless.
Any ideas? Thanks.
B2K24
  • Last login:June 10, 2025, 10:17:56 am
Re: Neo Geo Multi Slot Load Not Working
« Reply #1 on: April 14, 2018, 12:41:48 am »
mame64 neogeo -memc "J:\MAME\neogeocard.mc" -cart1 blazstar -cart2 mslug -cart3 kotm -cart4 nitd -cart5 pulstar -cart6 samsho
This works using 0.196
Make sure MAME can see your hash directory and neogeo.xml is inside it.
alex2005
  • Last login:November 28, 2025, 09:18:40 am
« Reply #2 on: April 14, 2018, 07:58:41 am »
How do you actually create the neogeocard.mc file?
brywalker
« Reply #3 on: April 14, 2018, 08:31:52 am »
Thank you for that. I haven’t found anything relating to the hash folder or that xml.
*edit - I GTS. testing now*
« Last Edit: April 14, 2018, 08:50:08 am by brywalker »
brywalker
« Reply #4 on: April 14, 2018, 09:58:39 am »
That was it dude. Thank you so much. Hash and neogeo.xml.
To do the memcard creation load a neo game and tab > file manager. You can create it there.
