Author Topic: Using J-PAC with an Makvision M2725C-82 monitor  (Read 2549 times)
alex_bb23
  • Last login:September 07, 2025, 03:16:03 am
  • I want to build my own arcade cabinet!
« on: April 11, 2018, 06:18:39 am »
Hello guys,
I own an Makvision M2725C-82 monitor which (according with technical specifications) can support resolutions 320 x 240 / 640 x 200. I intend to use this in combination with CRT Emudriver 2.0... So, windows desktop can run at 640 x 480i and I'm not sure if this monitor can be capable to deal with this resolution... Could somebody tell me if this will work?
Thank you!
buttersoft
  • Last login:Yesterday at 06:29:58 pm
  • Is running at 15kHz
Re: Using J-PAC with an Makvision M2725C-82 monitor
« Reply #1 on: April 11, 2018, 08:18:21 am »
It should work fine. Some sets handle interlaced modes better than others, with less flicker, but there's not normally a lot you can do about that.
And BTW you probably wanted to post this in the monitor/video section :)
alex_bb23
« Reply #2 on: April 11, 2018, 08:42:38 am »
Thanks to the ATI 5450 there is less flicker.
You're right! Could somebody move this post in the monitor/video section?
Thank you!
