Author Topic: generate mame xml for LEDBlinky  (Read 2774 times)
Hutt
  • Last login:December 31, 2022, 11:02:48 am
  • I like eggs.
« on: April 07, 2018, 08:22:53 pm »
Switching from HS to Launchbox and making some other upgrades to the cabinet at the same time.
Just updated from mame 147 to 195.
Generated a mame.xml for use with LEDBlinky.... it's over 200 meg... previous one for 147 was still 133meg.
Can I generate a file based on the roms I actually have? I only have a little under 200
The big problem with this is if I have LEDBlinky preload it then it throws my light timing off for the initial LB launch.
If I don't preload it the first time I select the MAME platform it must wait until then to load because my lighting is thrown off for a good 30 seconds at that point.
If I had an xml for only what I need it would probably be under 5 meg.
