Author Topic: Performace/audio fluctuation  (Read 2745 times)
TwitstedEpoch
  • Last login:April 03, 2021, 07:37:22 am
« on: April 06, 2018, 07:18:30 pm »
Hi all, has anyone experienced a strange performance fluctuation when playing some console games? It happens to me when playing SNES games on GM. The performance fluctuates between 98% and 102% which causes wobbly audio. The strange thing is that as soon as I hit TAB to bring up the menu, it stabilises and stays at 100%, even after closing the menu. Everything else seems to be working perfectly, including arcade games.
Video here:
I can't seem to create a log file for this as it's promoting for a software list which I'm not using. The roms are all controlled by my frontend unfortunately.
GroovyMAME 0.196
Sony BVM
Win 7
CRT Emudriver 2.0
Radeon 5XXX
Cheers.
« Last Edit: April 06, 2018, 07:48:42 pm by TwitstedEpoch »
TwitstedEpoch
Re: Performace/audio fluctuation
« Reply #1 on: April 06, 2018, 07:41:44 pm »
Quick update, I have worked out how to launch the rom via the command line by using the -cart option. Log file attached.
funkycochise
  • Last login:October 22, 2019, 07:35:18 am
  • 8 bits generation
« Reply #2 on: April 06, 2018, 11:14:17 pm »
this kind of issue is due to a lack of power.
I had similar problem with cave cv1k games. Until someone points the windows power plan.
before doing any tweak in gm or changing emulator, try this :
« Last Edit: April 06, 2018, 11:16:22 pm by funkycochise »
  • Last login:Today at 05:18:54 am
« Reply #3 on: April 07, 2018, 06:06:30 am »
Are you using frame delay?
TwitstedEpoch
« Reply #4 on: April 07, 2018, 11:20:18 am »
Thanks funkycochise, I have just checked and my system is already set to high performance.
Hi Calamity, my frame delay is set to 0.
funkycochise
  • 8 bits generation
« Reply #5 on: April 07, 2018, 04:00:38 pm »
what is your configuration ?
snes elulation should’nt be that demanding.
on a Intel i3, ck1k are working flowlessly.
and it’s much more demanding.
else you can try mednafen. there is a special build outta here.
maybe worth a try
TwitstedEpoch
« Reply #6 on: April 07, 2018, 06:24:29 pm »
maybe worth a try
I'm using a 5th gen i7 @ 4.0Ghz and 16GB of ram.
