Author Topic: Help: Wrong Mode with vertical Cave games?  (Read 2879 times)
Endprodukt
  • Last login:November 09, 2025, 01:49:52 pm
« on: March 30, 2018, 07:18:34 am »
All vertical Cave games run at 31.500 instead of 15khz, using super resolutions. Makes sense, as GM chooses a 480p mode. It just doesn't look right and a little blurry at 31.5khz.
What could I do about it?
funkycochise
  • Last login:October 22, 2019, 07:35:18 am
  • 8 bits generation
Re: Help: Wrong Mode with vertical Cave games?
« Reply #1 on: March 30, 2018, 08:47:10 am »
maybe you should try to play in vertical mode ?
Endprodukt
« Reply #2 on: March 30, 2018, 12:04:48 pm »
I have a horizontal screen. So I use horizontal mode. It works great with many vertical games. But it has problems with the 320x240 @60hz 15khz games.
josete2k
  • Last login:February 07, 2025, 08:39:53 pm
« Reply #3 on: March 30, 2018, 12:40:37 pm »
Better to set
rotate 0
And play them at fullscreen.
funkycochise
  • 8 bits generation
« Reply #4 on: March 30, 2018, 02:16:33 pm »
when resolution is too high, the result is bad.
and there is no magic to apply against this.
why not turn the screen to play as it was intended to ?
Endprodukt
« Reply #5 on: March 31, 2018, 03:21:24 am »
Because my screen is mounted into a cabinet and I don't have the luxury to turn it for Tate.
I doubt there is no way to make GM choose the correct resolution. Calamity was always able to help me in the past. Something is setup wrong for this specific resolution.
All the other vertical games work fine.
Endprodukt
« Reply #6 on: April 01, 2018, 02:39:36 pm »
I updated to the latest Version of GM and the Driver. It still picks 31khz. When I did some fiddeling I had it so it was picking a 24khz mode which looked slightly better but I really would want true 15khz.
Calamity
  • Moderator
  • Last login:Yesterday at 03:55:32 pm
  • Quote me with care
« Reply #7 on: April 03, 2018, 07:54:38 am »
So what would you like GM to do? Because you can't certainly do 320p@15kHz.
The correct resolution for Cave on a tri-sync is 2560x320 (24 kHz). Please pass me a log from latest version, it should be picking 24 Khz by default.
Steps to create a log:
