Author Topic: LCD help - I'm lost, confused and I want to go home!! (I've also got a log)  (Read 2373 times)
iVoid
  • Last login:April 01, 2018, 04:58:19 pm
So I'm familiar with mame but it's my first time using groovymame. I'm using an LCD and I want to reduce input lag as far as possible, but I can't for the life of me figure out how to make it do integer scaling. I've set "unevenstretch" to 0 but it seems to have no effect...
I edited the mame.ini to set "monitor" to "lcd", I've set "video" to "d3d", I don't know what's going on can anyone help me out?
Here's the log:
https://pastebin.com/FvSMhJcC
« Last Edit: February 25, 2018, 08:00:49 am by iVoid »
Calamity
  • Moderator
  • Last login:Today at 01:46:54 pm
  • Quote me with care
Try the settings from command line, e.g.
groovymame bublbobl -nofilter -nounevenstretch -nounevenstretchx
That should work. If it does, put those settings inside an .ini file other than mame.ini, e.g. raster.ini, horizont.ini, vertical.ini, etc.
Some settings in mame.ini can be bypassed by Switchres to allow automatic configuration. When they're set somewhere else, they get higher priority and GM can't touch them.
Steps to create a log:
iVoid
Thank you very much! It worked.
