Author Topic: JPac troubleshooting  (Read 1634 times)
jkimrey
  • Last login:February 14, 2021, 08:58:41 am
« on: February 17, 2018, 09:10:10 pm »
Finally getting around to rewiring my arcade with a J-PAC .
Right now the only thing hooked up to the JAMMA harness is the JPac and one button I'm using for a test, as well as two grounds going to the power supply.
When turning on the test light blinks quickly for a second and then turns solid green.
When I try notepad, however, there is nothing happening when pressing the button (I've tried player 1 and 2).
I've tried on two computers - on one I get "invalid USB device" showing in device manager. As soon as I uninstall the device it comes back.
On the other computer that doesn't seem to be happening but still no response.
I'm going to try to find a ps/2 keyboard so I can run in test mode but wanted to see if anyone had any other suggestions.
I also wanted to make sure that it's ok to test with only one thing hooked up to the harness (button) - I did make sure the ground I was using for the button was the first in the chain.
TIA.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: JPac troubleshooting
« Reply #1 on: February 18, 2018, 07:17:25 am »
Best to drop me an email about this. It sounds like an old board if it has PS/2 connectors.
The easiest way to test is to use a piece of wire connected to GND and touch to various of the white screw terminals.
But if you can email I will guide through troubleshooting: andy@ultimarc.com
