Author Topic: GroovyMAME audio issues  (Read 3014 times)
Jack
  • Last login:March 07, 2025, 06:28:36 pm
  • See You Space Cowboy..
« on: February 12, 2018, 08:09:34 pm »
I've tried playing with the Core Performance Options but the audio keeps slowing down at times (but the game doesn't seem to slow down) how can i fix this? Thanks
funkycochise
  • Last login:October 22, 2019, 07:35:18 am
  • 8 bits generation
Re: GroovyMAME audio issues
« Reply #1 on: February 12, 2018, 10:47:51 pm »
what is your os ?
Jack
« Reply #2 on: February 13, 2018, 05:15:12 am »
Windows 10 pro 64x
Ok i've installed the latest version of GM and i don't have the problem anymore, i thought that my roms wouldn't work with a newer version of mame.. at least it was what people kept telling me in an another forum O.o
EDIT: nope.. it keeps happening after few plays the issue is back :\
« Last Edit: February 13, 2018, 06:34:43 am by Jack »
funkycochise
  • 8 bits generation
« Reply #3 on: February 13, 2018, 07:10:41 am »
When you have audio issue, it usually shows a cpu drop
Try to upper your windows profile to the max, it solves the problem for me (allowing to get rid of that triplebuffer setting) :
https://www.howtogeek.com/240840/should-you-use-the-balanced-power-saver-or-high-performance-power-plan-on-windows/
Before knowing this, I wasn't even aware of a setting able to make the OS force a demanding application to slow down
« Last Edit: February 13, 2018, 07:19:45 am by funkycochise »
Jack
« Reply #4 on: February 13, 2018, 08:44:45 am »
Ok thanks, i've done it.. let's see how it goes, for now seems ok but i want to give it more time to be sure.
EDIT: i can confirm that this solved the issue.
« Last Edit: February 18, 2018, 05:46:22 am by Jack »
