Author Topic: Design advice for an Optical PCB for trackball /spinner  (Read 1679 times)
jimmer
  • Last login:February 17, 2025, 02:48:38 pm
  • I want to play Defender like at the arcade.
« on: February 12, 2018, 09:42:53 am »
I'm looking for some help or advice from electronics guys.
Q1: What's with all the components on the happ pcb?  Is it just signal conditioning?  Using a pro-micro as encoder, I get the same result with just 2 optosensors and 1 resistor to limit the current to the emitters*
Q2: What would be a rough cost for pcb manufacture. Qty 100, 40mm x25mm.  With holes for 2 optosensors, 1 resistor, and a 4 pin header. I haven't tried to work out how many layers are needed.
Q3. How much to design the pcb for me and send me the files to order it ?
Q4. Also I need help to choose a suitable opto sensor (eg small 12mmx5mm like the Happ) the ones I used before are larger and I didn't choose them.
*actually that was on a big tempest optical wheel, I haven't tried it on a small trackball opto wheel.
« Last Edit: February 12, 2018, 10:15:59 am by jimmer »
On forums jimmer speaks for himself as a Defender fan, not as proprietor of www.jbgaming.co.uk  << Is that advertising or disclosure ? or both ?
StefanBurger
  • Last login:October 28, 2025, 10:44:03 pm
Re: Design advice for an Optical PCB for trackball /spinner
« Reply #1 on: February 12, 2018, 04:41:57 pm »
Some time ago, I designed a spinner with electronics. Maybe you find some usefull informations:
https://www.thingiverse.com/thing:2021152
https://hackaday.com/2017/01/23/awesome-illuminated-arcade-spinner/#more-240635
jimmer
« Reply #2 on: February 12, 2018, 06:58:21 pm »
I did find it very useful, thanks.  I bought those ITR9608 and added your arduino interrupt routines into my HID encoder  :)
I found a small sensor with similar specs so will try that   http://www.farnell.com/datasheets/1829985.pdf?  I'll test the simple circuit and then work out how to get the boards made.
« Last Edit: February 12, 2018, 08:46:08 pm by jimmer »
