Author Topic: Potentiometer pedal  (Read 1637 times)
tjackson8685
  • Last login:February 10, 2018, 03:58:56 pm
Potentiometer pedal
« on: February 10, 2018, 03:38:27 pm »
Hello:
I have searched the forums unsuccessfully so posting a new thread with my question. I am trying to connect a Happ potentiometer pedal to my MAME cabinet using a U-HID board.
I have soldered three wires to the three tabs on the potentiometer. These have been connected to three pins on the U-HID board
It is my understanding I need to configure the three pins as:
       (a) Analogue input
       (b) Ground
       (c) +5v
Question - does it matter which pin is configured to each of the above (e.g. does the middle tab on the potentiometer have to be ground)
Thank you very much.
Tim
baritonomarchetto
  • Last login:Today at 02:41:34 am
Re: Potentiometer pedal
« Reply #1 on: February 10, 2018, 03:57:23 pm »
The middle pin is always wiper (analog out). The other two are 5v and gnd: if the pedal works reversed, reverse 5v and gnd.
tjackson8685
« Reply #2 on: February 10, 2018, 03:58:56 pm »
Thank you!
