Author Topic: Led Blinky and Control Board Help  (Read 2074 times)
Propdept
  • Last login:June 16, 2022, 05:26:16 pm
« on: January 27, 2018, 06:44:19 pm »
First of all let me apologize if I am posting this question in the wrong subsection
Let me first explain what I want to do.....
I am building an arcade game cabinet and I would like to use LED Blinky for accent lighting,
 None of the buttons on my control panel will light up. LED Blinky does have one function I do want for MAME and that is, it announces the name of the game. This is something that I will incorporate into my cabinet.
 In my game cabinet I have a jukebox program and I want to use LED Blinky for accent lighting using RGB tape light as seen below in my picture
PICTURE ONE
In the next picture is how I want the RGBLED tape lights to be located
PICTURE TWO
I think the setting “color intensity spectrum” will work perfectly for my cabinet. As the music is playing, the LED’s will create a “light organ effect”. The length of each LED rope light will be approximately 12 to 18inches long.
Now this is where I need your help, advice, and recommendations based on your wisdom!
1)       What Led Board would you recommend based on my needs? I know that Ulitmarc Selsl two controllers The PAC LED 64 & the PAC Drive  I am worried about the voltage needed to make three 18 to 24 inch RCG LED tape lights  work.  :badmood:
2 Will my idea work?  :banghead:
3 if so what must I buy to make it work?
I am  NOT very versed on electronics.  I understand voltages/watts/ adapter polarity but please understand my electronic electrical knowledge is limited. :dizzy:
An y and all help and suggestions  would be appreciated...
THANK YOU!!!!!!! :notworthy:
