Author Topic: CP joystick neutral wire daisy chain ran out of quick connects  (Read 3440 times)
80sarcadegames
  • Last login:October 01, 2025, 09:41:51 am
« on: January 25, 2018, 12:07:15 pm »
As per my photos below,  I purchased a jamma wiring harness and cut out the wires to wire up the control panel.
The wiring harness came with a "daisy chained" black wire I used for my neutrals to daisy chain everything but it ran out of quick connects.
I have a pile of wires on the floor as you can see where on the one end of each wire is a quick connect and the other end is just a wire end without anything.
Should I buy some quick connects and buy a tool to add more quick connects to finish daisy chaining everything.
Should I buy a new wiring with more quick connects in the daisy chain?
80sarcadegames
Re: CP joystick neutral wire daisy chain ran out of quick connects
« Reply #1 on: January 25, 2018, 12:11:06 pm »
Here is the very end of the current daisy chain. This was the end that I cut off the jamma harness I guess.
Should I add more daisy chains of quick connects? If so, don't I need a tool to add more quick connects?
80sarcadegames
« Reply #2 on: January 25, 2018, 12:14:36 pm »
Close up of the end of the wire. No more quick connects in the chain.  :'(
And below is the jamma wiring harness after I cut the wires off.    :laugh:
80sarcadegames
« Reply #3 on: January 25, 2018, 12:16:24 pm »
An example of the extra wires I have cut from the jamma wiring harness that I may have to use to add to the daisy chain.   :banghead:
One end has a quick connect , the other is just an end of wire.
  • Bitches love Centipede
« Reply #4 on: January 25, 2018, 12:43:41 pm »
The reason you ran out of QDs is because the CP you've built does not fit the JAMMA Standard:
Games that had more than 3 buttons required an additional harness, called a kick harness due to the fact that most of the games that required the additional harness were fighters.
Anywho... onto moving forward with your project. Buy some insulated QDs, a little bit of wire, and a cheap crimper down at your auto parts store and just keep building off that daisy chain.
%Bartop
80sarcadegames
« Reply #5 on: January 25, 2018, 12:50:12 pm »
Wow.  Thanks!!!!
I really screwed up with doing my research, huh?    :banghead: :banghead: :cry: :dizzy:
« Reply #6 on: January 25, 2018, 12:53:26 pm »
Lotta ---steaming pile of meadow muffin--- to sift through...
%Bartop
80sarcadegames
« Reply #7 on: January 25, 2018, 01:55:54 pm »
I guess I need to buy female QDs.
There are a few different sizes.
Is this the right size?
https://www.amazon.com/Female-Insulated-Disconnect-Terminal-14-16ga/dp/B001H3KMYS
« Reply #8 on: January 25, 2018, 02:25:46 pm »
Look for 18-20 GA
80sarcadegames
« Reply #9 on: January 25, 2018, 03:17:17 pm »
