Author Topic: Ami-Rowe R90 Power Supply  (Read 3220 times)
Surreyjukeboxuser
  • Last login:January 23, 2018, 12:29:19 pm
« on: January 19, 2018, 04:25:20 pm »
I purchased an Ami-Rowe R90 when I lived in the USA and used it successfully on USA power.  I have now bought the machine back to the UK with me.  Looking at a manual I have found and also looking at the power supply it would appear that the power supply is automatically dual voltage.  On this basis, I am presuming that I do not need a step down transformer to use it in the UK and the records will also play at the correct speed.  Am I correct in my assumptions?
« Last Edit: January 20, 2018, 09:24:59 am by Surreyjukeboxuser »
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Ami-Rowe R90 Power Supply
« Reply #1 on: January 23, 2018, 06:30:12 am »
Hello surrerjukeboxuser,
I spoke with you yesterday regarding your jukebox and said that you would require a stepdown transformer or a replacement power supply (junction box) and a 50 hz turntable belt pulley.
I await your motor plate arriving and we will supply you with a 240 volt power supply.
Regards
Alan
Alan Hood
ami-man
UK
Surreyjukeboxuser
« Reply #2 on: January 23, 2018, 12:29:39 pm »
Alan,
The plate was sent to you today
ami-man
« Reply #3 on: January 29, 2018, 06:06:14 am »
Hello Nigel,
Have you recieved the parts? and have these now rectified your problems?
Regards
Alan
Alan Hood
ami-man
UK
