Author Topic: Need Help With Pole Position wheels with an Opti-Pac  (Read 3235 times)
jalamaac
  • Last login:February 03, 2018, 05:34:28 pm
« on: January 10, 2018, 05:02:24 pm »
i have a Pole Position and i am trying to hook up the Opti-Pac but i seem to not get any mouse movement... anyone have a how to or information on something i may be doing wrong. hear is my board atached
  • Last login:Yesterday at 02:45:09 pm
Re: Need Help With Pole Position wheels with an Opti-Pac
« Reply #1 on: January 10, 2018, 07:02:15 pm »
X1 and X2 are the data lines.
Set your multimeter to Volts and check the following:
1. Is ground connected to the ground pin?
2. Is 5v connected to the 5v pin?
3. When you slowly turn the wheel, do the data lines alternate between logic high (near 5v) and logic low. (near 0v)
- A line that is stuck high or low points toward a bad opto. (or possibly a bad board)
This quadrature waveform shows what you would see on the data lines (A and B) when you slowly turn the wheel clockwise.
If both data lines are working but the Optipac still won't output mouse movements, check out this related thread. Andy's suggestion below.
EDIT: Didn't notice earlier that this optical board is an "active high" device.   :banghead:
« Last Edit: January 11, 2018, 03:55:16 am by PL1 »
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #2 on: January 11, 2018, 03:19:35 am »
The PCB layout indicates the outputs are pulled high and float low.
This is the opposite to most setups and not the default of the Opti-PAC. But this can be changed using the utility for the Opti-PAC which can be used to set the type of inputs.
See http://www.ultimarc.com/optipac3.html for details.
jalamaac
« Reply #3 on: January 11, 2018, 08:57:01 am »
That worked thank you so mutch guys.
« Last Edit: January 11, 2018, 09:09:01 am by jalamaac »
