Author Topic: Wanted new/used rotary joystick and spinner setup  (Read 2797 times)
Customcade
  • Last login:March 05, 2026, 04:26:21 pm
« on: January 03, 2018, 06:55:56 pm »
Wanted new/used rotary joystick and spinner setup.
Looking for a both or either and whatever I need to make them work on PC.
  • Last login:Today at 03:27:55 pm
Re: Wanted new/used rotary joystick and spinner setup
« Reply #1 on: January 03, 2018, 11:51:09 pm »
Spinners:
If you're buying new, it's hard to beat the TT2 spinner from GGG, but the SpinTrak from Ultimarc comes very close.
If you buy a used arcade spinner, you'll need an optical (mouse) encoder like one of these to translate the quadrature waveforms to mouse movements.
- OptiWiz from GGG
- StefanBurger's Illuminated Arcade Spinner firmware on an Arduino. (the firmware is on the linked Thingiverse page)
Rotary Joysticks:
There are two basic types of rotary joystick:
1. Mechanical Rotary -- the "clicky" 12 steps per rotation type used in Ikari Warriors and the majority of other rotary joystick games.
Happ P/N 50-5618-00 available at arcadeemulator.net.
You will also need a rotary encoder to translate changes in the rotary switch position into keystrokes.
- KADE miniArcade (if you find the old Minimus board) or KADE miniArcade 2.0 (works with a wide variety of 32u4 AVR boards)
- GP-Wiz40 by GGG
- Rotary Joystick Interface by Ultimarc (only handles the rotary function, expensive and non-programmable, but it is plug-and-play easy)
Mechanical rotary stick settings from the wiki.
MAME Settings for Mechanical Rotary Joysticks
For mechanical rotary games:
Input (this Game) menu
    Positional Analog to none
Analog Control menu
    Positional Digital Speed = 0
    Positional Sensitivity = 100
For optical rotary games:
    Dial Analog to none
Analog Control menu
    Dial Digital Speed = double the default value
    Dial Sensitivity = default value
2. Optical Rotary -- the "non-clicky" 24 steps per rotation type used in only 4 games.
    Caliber .50
    Exterminator
    Touchdown Fever
    Touchdown Fever II
Happ P/N 50-5619-00 available at arcadeemulator.net.
You can use a separate axis on the spinner's optical (mouse) encoder. (i.e. spinner on X-axis, rotary joy on Y-axis)
Customcade
« Reply #2 on: January 05, 2018, 01:12:41 am »
Thanks for the info I know what I wanted but did not know what I actually needed but do now...
A mechanical rotary is what I was after and will look into ggg spinners.
Thanks for the info!
