Author Topic: Pandora's Box and Zero Delay encoders with Sanwa Joysticks  (Read 5404 times)
hypergaming
  • Last login:May 04, 2022, 09:51:07 pm
« on: January 03, 2018, 05:36:32 pm »
Hi everyone,
I recently purchased a Pandora's Box Multigame board, and I guess I purchased the wrong joysticks for it, I see that Pandora's box uses a Jamma harness, where the button functions need to go to the regular  arcade switches. The problem is that my Sanway Joysticks do not have the regular switches, they have a 5 pin wire that goes connected right to the zero delay encoder.
is it impossible to use Sanwa joysticks with a Pandora's box?
attached are images of what I purchased
Titchgamer
Re: Pandora's Box and Zero Delay encoders with Sanwa Joysticks
« Reply #1 on: January 03, 2018, 05:38:43 pm »
You could still use them but you would have to splice them onto the normal Jamma harmess.
Not sure where the ZD comes in??
hypergaming
« Reply #2 on: January 03, 2018, 05:58:33 pm »
Thanks for replying, just not sure how I would wire to Jamma, that came with the sanwa joystick is just one cable with the pin connector, now sure I can strip and splice to Jamma, but I will try to get more info on it and also see who else replies, thanks again!!
Titchgamer
« Reply #3 on: January 03, 2018, 06:25:30 pm »
Thats exactly what you do.
Cut and strip each wire then splice it to the respective U,D,L,R and Ground wires of the Jamma Harness.
hypergaming
« Reply #4 on: January 03, 2018, 07:34:24 pm »
But isn't the Sanwa 5 pin cable 5 cables? how do I know which ones are up, down, left and right? what about the 5th cable? I'm just asking without opening the cable yet :)
thanks again
  • Last login:Today at 09:15:18 am
« Reply #5 on: January 03, 2018, 10:22:13 pm »
thanks again
I think this is the diagram you're looking for.   ;D
hypergaming
« Reply #6 on: January 03, 2018, 10:39:36 pm »
Thanks! great diagram, I will give this a try tomorrow and let you guys know how it went, thanks again!
