Author Topic: Monitor Identification  (Read 5965 times)
imtrashed
  • Last login:January 03, 2020, 02:47:10 pm
« on: December 27, 2017, 03:50:33 pm »
I can't seem to figure out what I have.  The cabinet I picked up has been rebuilt with a X-Arcade CP, so I'm not sure everything else in here is original, but it was/is a High Impact Football cabinet.  Attached are pics of the monitor, tube, chassis.  Anyone able to tell from these?  It's old, for sure.  Appreciate any feedback.
Ken Layton
  • Guru
  • Technician
Re: Monitor Identification
« Reply #1 on: December 27, 2017, 10:39:40 pm »
From the monitor I.D. website:
http://homearcade.org/BBBB/4600.html
imtrashed
« Reply #2 on: December 28, 2017, 09:32:04 am »
Thank you!  Been trying to identify it but couldn't find a match.  Appreciate it!
Now if my picture is shifted to the right, do you know if there is a Horizontal Position potentiometer?  I can't seem to locate one, and don't see one in the manual.  Do I just adjust the Horizontal Width Coil to make it fit on the viewable screen?  Other solutions?
princess prin prin
  • Last login:Today at 01:00:50 pm
  • intrinsically safe
« Reply #3 on: December 28, 2017, 09:44:35 am »
The tube is from a Hantarex MTC9000 but the yoke has been swapped.
imtrashed
« Reply #4 on: December 28, 2017, 09:47:57 am »
That was one of the reasons I couldn't identify it.  Was looking through Hantarex monitors.  But just the tube is Hantarex.  :)
imtrashed
« Reply #5 on: December 28, 2017, 09:49:35 am »
Ken, I've been reading through lots of your older posts regarding this monitor on some other forum threads.  Is it possible I do not have the Horizontal Centering Potentiometer on mine?
Ken Layton
  • Guru
  • Technician
« Reply #6 on: December 28, 2017, 11:25:20 pm »
imtrashed
« Reply #7 on: December 29, 2017, 08:17:12 am »
The last page of this K4600 service manual shows the adjustments:
http://arcarc.xmission.com/PDF_Monitors/Wells%20Gardner%2019k4600%2019k4625%2019k4675%2019k4676%2019k4677%2019in.pdf
Bob Roberts shows the horizontal hold:
http://homearcade.org/BBBB/slanted.html
You're the man.  I will take a look and try to remedy tonight.  Really appreciate it.  Hopefully, you've saved me from dismounting and bringing to a repair guy for $85 per hour to troubleshoot and turn a little knob.  :)
I get some off colors in the bottom left and top right corners.  Hoping I can just use a degaussing wand to fix that, but do you think it's perhaps something else that needs fixing?  Caps?  I'd really rather not put a new cap kit in, but maybe down the line.
Ken Layton
  • Guru
  • Technician
« Reply #8 on: December 29, 2017, 12:04:18 pm »
A degaussing coil is much better than a whimpy wand.
imtrashed
« Reply #9 on: December 29, 2017, 01:09:19 pm »
Right, but where can I find one?
imtrashed
« Reply #10 on: December 29, 2017, 06:33:36 pm »
Here are a few pics of my monitor, one at the same angle as the schematic from the last page of the manual.  Looks like I have no Horizontal Video Position, right?
Ken Layton
  • Guru
  • Technician
« Reply #11 on: December 29, 2017, 10:30:00 pm »
Yes, you do have the horiz and vertical adjustment jumpers installed.
imtrashed
« Reply #12 on: December 30, 2017, 09:41:26 am »
But no potentiometer that I can find.
Ken Layton
  • Guru
  • Technician
« Reply #13 on: December 30, 2017, 12:29:56 pm »
The horizontal hold and vertical hold controls are on the "hor/ver" board (a.k.a. the "X/Y" board).
imtrashed
« Reply #14 on: December 30, 2017, 02:19:11 pm »
Thanks, but still looking for Horizontal Position (not the hold pots).
behrmr
« Reply #15 on: December 30, 2017, 02:27:21 pm »
There isn't a POT there is only a jumper.  If that isn't getting your image where it belongs then you may have a problem with the horizontal frequency.  There is a POT on the X/Y card to adjust hold as well as a L351 coil on the X/Y board.  Again, as Ken indicated, check the last page of the service manual items #6,#7,#9.
